temporarily lost drive
/ temporarily lost drive #1
Redracer
NewYork
Cub Cadet 5234D
I am enjoying my new found freedom from the plow guy. I just cleared the second 12+ inch snowfall.
While doing so I lost drive, the tractor was running, I checked everything and all looked ok. I was getting a tow cable and the 4x4 started up the pull itout of the way when I decided to try it once more. It was still idling fine and I just depressed the pedal and off she went. It did this once more soe 20 minutes later .
Any idea's ? It was 6 degree's out .
Thanks
STill havent gotten the blower hooked up yet.
/ temporarily lost drive #2
Good morning,
Any chance the Hi/Lo slipped out of gear.
There was a recall on the 5252 for this, not sure about the 5234's
Curt
/ temporarily lost drive #3
I know I've mentioned this in previous post and I hope that this is not the case with your tractor, however, according to my dealer the ring and pinion were a common problem with the 5000 series. It may be that yours is starting to go out and will catch periodically. This may be a possibility, hopefully its something much less serious though. I do not remember seeing recall info when I had my 5234D for the shifting...but that doesn't mean there wasn't one for that model. Please keep us informed, hope you get it figured out.
/ temporarily lost drive #4
Hope you get it figured out. I am a sencond owner of a cub 5252 05' can I go back to a dealer to get it replaced? Does it have to fail first? I suppose not, that is the point of a recall.
Dupa
/ temporarily lost drive #5
I believe this recall was to correct a problem where the tractor would slip out of gear on a hill and start freewheeling. That would be bad news on a hilly property.
Curt
/ temporarily lost drive #6
Any updates on this? I hope it was nothing major.
2022 EZ-GO ELITE...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
2021 John Deere S790 S Combine (A63111)
2021 John Deere...
