temporarily lost drive
/ temporarily lost drive #1
Redracer
NewYork
Cub Cadet 5234D
I am enjoying my new found freedom from the plow guy. I just cleared the second 12+ inch snowfall.
While doing so I lost drive, the tractor was running, I checked everything and all looked ok. I was getting a tow cable and the 4x4 started up the pull itout of the way when I decided to try it once more. It was still idling fine and I just depressed the pedal and off she went. It did this once more soe 20 minutes later .
Any idea's ? It was 6 degree's out .
Thanks
STill havent gotten the blower hooked up yet.
/ temporarily lost drive #2
Good morning,
Any chance the Hi/Lo slipped out of gear.
There was a recall on the 5252 for this, not sure about the 5234's
Curt
/ temporarily lost drive #3
I know I've mentioned this in previous post and I hope that this is not the case with your tractor, however, according to my dealer the ring and pinion were a common problem with the 5000 series. It may be that yours is starting to go out and will catch periodically. This may be a possibility, hopefully its something much less serious though. I do not remember seeing recall info when I had my 5234D for the shifting...but that doesn't mean there wasn't one for that model. Please keep us informed, hope you get it figured out.
/ temporarily lost drive #4
Hope you get it figured out. I am a sencond owner of a cub 5252 05' can I go back to a dealer to get it replaced? Does it have to fail first? I suppose not, that is the point of a recall.
Dupa
/ temporarily lost drive #5
I believe this recall was to correct a problem where the tractor would slip out of gear on a hill and start freewheeling. That would be bad news on a hilly property.
Curt
/ temporarily lost drive #6
Any updates on this? I hope it was nothing major.
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
2022 EZ-GO ELITE...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
John Deere 6110M (A64126)
John Deere 6110M...
