TEMPERATURE SENSOR OR GAUGE ?
/ TEMPERATURE SENSOR OR GAUGE ? #12
Well, I figured out my gauge is shot, The coil inside is broken & the tiny wire is uncoiled
(Wonder how that happened)
Bob Rooks,
My neighbor gave me a new SunPro 12v Gauge that is mechanical & the sensor fits in block ok,
Not quite as long as original.
No electrics needed except light if wanted
The original gauge had 2 red wires for 12v & 1 orange wire for the sensor
Since this sensor has a spring encased tube to the gauge , no wiring is required is it ?
David
It has a capillary tube connected to a bulb that is immersed in the coolant. The bulb and tube are filled with glycerin and it expands and contracts proportionally to the coolant temperature. The only electrical connection required is for the lamp. The spring protects the capillary tube.
Thank you guys very much,
I will put it in, it even came with a mount for the larger hole
Now, If I can just get my big hands & arms in there to isolate those wires
David
OK,
Installed mechanical SunPro gauge & sensor
Let engine run for 20 minutes at medium rpm, needle never moved (100 degees)
Warm engine, not hot, removed radiator cap with very little coolant loss
Thermostat..?
David
/ TEMPERATURE SENSOR OR GAUGE ? #15
Thermostat is stuck open or you don't have the doughnut seal on top of it.
See Tommy's post #3.
I put a piece of radiator hose on thermostat and got warmer, gauge reads 180
BUT, Sun Pro gauge must be interior only as a little rain caused condensation & glass fogged up
/ TEMPERATURE SENSOR OR GAUGE ? #17
Yup. They aren't Stewart Warner or Murphy.
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
2016 KOMATSU PC138USLC-10 EXCAVATOR (A62129)
2016 KOMATSU...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
Iranch IRGC40 (A60463)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 Chevrolet Colorado Crew Cab Pickup Truck (A61568)
2018 Chevrolet...
