Temperature Gage Reading
/ Temperature Gage Reading #1
Spaceman
Ct
Kubota B2100
I have a Kubota B2100 and the temp gage barely gets above the cold mark. Is this normal or should I change the stat?
/ Temperature Gage Reading #2
The gauge on my F2400 has a break in the line just above the cold end and that is where the needle sits when the engine is warmed up. I don't think you need to change anything.
/ Temperature Gage Reading #3
My B3030 when I had it was the same way, just above cold when warmed up. Only time it ever got higher was in the heat of summer with the cab AC on :D
/ Temperature Gage Reading #5
My Kubota B7510HST ran that way. Only time the gauge moved upscale much is when air flow became restricted through the radiator during mowing with the brush hog.
/ Temperature Gage Reading #6
My kubota MX5000 will not even move the temp guage to the half way point when work at PTO speed all day on a hot summers day.
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
Schuler 125B Feed Wagon (A66408)
Schuler 125B Feed...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
DT200 Diesel Tank (A64194)
DT200 Diesel Tank...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
