Temperature Gage Reading
/ Temperature Gage Reading #1
Spaceman
Member
Ct
Kubota B2100
I have a Kubota B2100 and the temp gage barely gets above the cold mark. Is this normal or should I change the stat?
/ Temperature Gage Reading #2
The gauge on my F2400 has a break in the line just above the cold end and that is where the needle sits when the engine is warmed up. I don't think you need to change anything.
/ Temperature Gage Reading #3
My B3030 when I had it was the same way, just above cold when warmed up. Only time it ever got higher was in the heat of summer with the cab AC on :D
/ Temperature Gage Reading #5
My Kubota B7510HST ran that way. Only time the gauge moved upscale much is when air flow became restricted through the radiator during mowing with the brush hog.
/ Temperature Gage Reading #6
My kubota MX5000 will not even move the temp guage to the half way point when work at PTO speed all day on a hot summers day.
2012 Volkswagen Jetta Sedan (A61569)
2012 Volkswagen...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
LOOK! (A63109)
LOOK! (A63109)
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
