Temp light at low rpm
/ Temp light at low rpm #1
Tom_Stewart
Richmond,TX
Yanmar YM 2500
I am about to finish this rehab project on a ym2500 when I found another problem...after running at 2500 rpm for a while in my neighborhood, I pulled up to my shop and lowered the rpm to idle (approx 800 rpm) the temp light then came on....increased idle back to 1800-2000 and the light went off after 5-10 seconds or so....
I let it cool and took radiator cap off, cranked it and water appears to be circulating well....the temp sensor is new.....
Service manual does not show a thermostat and given that the water appears to be circulating ok; What should I look for next.....no water leaks and no water in oil...
Thanks,
TS
/ Temp light at low rpm #2
Would be nice to know actual temp. maybe get an infrared thermometer, check it at different running settings see if there is a difference in temp when idling vs 2000rpm.
I see it's a new sender, was it replaced because of this? if not could be bad new part, I see that too often in auto repair parts. could be worn out waterpump vanes. You said no fluid loss, so don't think it would be head gskt, but be careful make sure all the air is bleed out. could be radiator is partially clogged, or even engine block coolant passages could be blocked partly. but before I'd get too into repairing I'd want to know what the real engine temp is when warning light is on..check many different places on block and head- see if anything is too high( besides the exhaust system)...good luck
/ Temp light at low rpm #3
I think this $10 gadget from Harbor Freight is sufficient for troubleshooting.
Harbor Freight non-contact thermometer
That light might be connected to the oil pressure sender, or alternator. I would double-check that it is wired to the temp sensor, as the first troubleshooting step. Try grounding the wire at the temp sensor to turn the light on. Also look for unintended grounds along the length of the wire. And when overheating turns the light on, pull the wire off the sensor and verify that the light goes out.
/ Temp light at low rpm #4
Good thinking.. diagnosis is a process of elimination. checking that the light is properly hooked up is a good first step.
/ Temp light at low rpm #5
I have tried using these lazer therometers when doing a/c work & they aren't even close to the actual temp ( mabe I paid too much for my unit :D ) anyway, I ended up buying a clamp on temp. reader. I would check my sending unit & air flow across the radiator at idle or low RPM.
/ Temp light at low rpm #6
Have you tried tightening your fan belt?
/ Temp light at low rpm #7
Since no one has mentioned it, I'd also check on system voltage. What is the voltage when Idling and what is it at higher rpm's. How quick did the light come on when you reduced the rpm's? If within a sec or two I would focus on electrical. Turning off 5-10 sec after increasing engine speed could just be a sign of low battery and taking a little time to get battery voltage back up again.
Thanks for all of your valuable input....Here is what I have done so far....
I took off the radiator cap and ran up rpm to 2500....after some of the fluid vibrated out....I noticed that occasionally I would get a bubble or two....let it run for 15 or 20 minutes to get rid of air and tried to replicate the hot light and it did come on at low idle....usually took 5-10 seconds to light up....
So, I took off the radiator and took to a radiator shop.....He called me back a couple of hours later and said that the radiator would have to be re-cored at best....too many clogs that he couldn't get free.... so I decided on a new radiator.
I went ahead while I was there and took off the water pump and inspected...no leaks and the pump looks great......
Ordered a radiator and water pump......
I now think that the radiator just wasnt circulating well.
Thanks again for all of your input.....tractor is looking great...I will post some pictures soon.
TS
Will keep one of the pumps as a backup.....
/ Temp light at low rpm #9
Be sure to replace the fan belt sinse its off already:D
/ Temp light at low rpm #10
Hope the radiator repair takes care of the problem. When you mentioned air bubbles, thought of bad head gasket come to mind.
I think MickeyFX was correct with the electrical diagnosis...replaced radiator and water pump and light still comes on....no water in oil and I measured the water in the radiator and it was 150 degrees....
Looks like I'm gonna have to trace every **** wire to correct this problem....I really don't trust these lights anyway....I think I'm gonna put a mechanical water temp and oil pressure guage on and be done with it.
TS
/ Temp light at low rpm #12
If my WAG turns out to be correct, wish I could have offered it prior to your buying rad and WP.
MickeyFX was correct...traced all wires yesterday and got all wiring connections straight and guess what.....dummy lights now work correctly, lights work correctly...I also have a spare water pump....I will post some pics of the total rehab this pm.
TS
/ Temp light at low rpm #15
Good Job. I believe that I need to do the same with my 1510D Viet rebuild, but have not taken the time to do it yet.
Mike
/ Temp light at low rpm #16
TS
:D Glad she's fixed Tom.
/ Temp light at low rpm #17
TS
Thats great, overheating is a baaaad thing for a diesel or gas engine..glad you're back on normal tractor rehab repairs...;)
/ Temp light at low rpm #18
Glad to hear its fixed.
Just to ask without having to start a new 'thread', How do I test the temp light on my YM2500? I'm really not sure if its working or not.
/ Temp light at low rpm #19
Simple answer. Find the temp sender and disconnect it then ground the wire to block or head ..see if light comes on..
but it should light up with key on engine off, without disconnecting anything.( most engine works that way, disregard this part of post if the yanmar doesn't)
/ Temp light at low rpm #20
Or ... slide the connector slightly off the sensor, then touch a grounding wire to the sensor's pin. (because the wire's terminal is a socket that is difficult to touch directly to ground.)
That's a preferable design, but these don't. The only time you see the light is when the sensor grounds due to overheating. The manual says remove and test the bulb at regular intervals, but grounding it like you and I said is easier.
2015 CATERPILLAR AP1000F ASPHALT PAVER (A65056)
2015 CATERPILLAR...
2013 TIGERCAT 720E FELLER BUNCHER (A65056)
2013 TIGERCAT 720E...
2008 Audi A4 AWD Sedan (A66738)
2008 Audi A4 AWD...
2015 SUNDOWNER 25 T/A ENCLOSED TRAILER (A67714)
2015 SUNDOWNER 25...
2005 Ford F-450 Crane Service Truck (A66736)
2005 Ford F-450...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
