Price Check Temp gauge
/ Temp gauge #1
branman1971
Texas
Yanmar YM1700
My temp sensor is bad and light stays on even from cold. Has anyone installed a temp gauge? They sell one at Hoyt but I am looking all over for one and wondered if anyone has one and how do you like it?
/ Temp gauge
I mean the one from Hoyt...
/ Temp gauge #4
Pull the wire from the sender and the light should go out. then ground it to a screw or metal and it should come back on. That will rule out the wireing. When you plug it back in and the light comes on then the sender is bad. I just use the idiot light and on hot days call me old school but I just stick my hand down by the dash and feel the air from the fan blowing back. works for me and I can tell the difference on hot days. And knowing my light is in good working order I'll shut it down if should come on. Been like that since the Mid 70's.
Carey
/ Temp gauge #5
I added gages on my 3810D but I got a small diameter el cheepo (or should I say el chino) 3 gage set at O'Reileys and tee'd it all in.
Its not necessarily a good idea to tee a coolant temp gage but its still a reference and that's the key knowing what is "normal" operation there are no extra holes to use in the block, I still have my idiot lites hooked up too btw.
/ Temp gauge
I looked for some temp gauges today but I didn't know what size and thread the temp sensor was. Does anyone happen to know this info? I couldn't find a nut at the auto parts store that fit on the sensor nice, and I thought maybe it uses pipe thread but the sensor felt loose inside a pipe threaded fitting.
/ Temp gauge #7
The temp gauge adapter is 15mm/coarse thread. I have one here.
Have I got a deal for you!:D (buyer beware). I bought an expensive street-racer grade temperature gauge and the adapter then never installed them. The gauge is AutoMeter 4337, NAPA 70-1630. I would be happy to sell it, lets say $10 below the best online price you can find then add Priority Mail at cost. I'll take a photo and post it if you (first call) or anyone else is interested in it.
What a deal!!!
Actually my serious advice is just get the light working and rely on it. That is what I decided to do. But if you want to get your new tractor all tricked out - this meter is the only one good enough for it. :thumbsup:
Photo: Summit Racing.
/ Temp gauge
Radiator looks rough. I know it leaks a little bit around the top cap and it looks like it has been repaired a few times. I know a good little radiator shop nearby that takes good care of my family, but if they can't fix it and make it look decent I might just have to get a new one. I have seen them for about $250+.
/ Temp gauge #9
If I were you I would spend the money on a new radiator and original-type sensor, and forget a new gauge and waterpump. The designers knew what they were doing. There's no need to modify it away from the original design.
/ Temp gauge
That's my plan. I just ordered the new sensor and upper and lower radiator hoses. Hopefully in a couple weeks I can order a new radiator.
/ Temp gauge #11
Thank for the PM. I agree, bringing it up to spec is a better use of money.
Does anyone else want this gauge on the same terms? Please PM if interested.
/ Temp gauge #12
Yanmar uses British Standard Pipe Thread.
/ Temp gauge #15
... on the oil pressure fitting.
Could be, but it seems that a lot of guys have had to chase the threads with a metric tap to get it to work.
Norm I assume you are talking about the oil sender since that is what you quoted.
My one-liner post above replaced a longwinded explanation I drafted then decided that nobody wanted to read. Here is the detail supporting what I said:
My 1/8 NPT brass fittings appeared to have the same thread as Yanmar's oil sender. I found that 1/3 of them would screw into the Yanmar block and 2/3 were too large diameter. It appears that BSP specifies more taper, smaller OD at the tip, on the OD of the threaded part.
Trying several brass fittings, I observed that NONE of the fittings that would go in had visible damage after being screwed into the Yanmar block. And both sensors screwed in properly after this experimenting indicating my brass fittings hadn't botched the block.
Conclusion: Some NPT (American) fittings have enough taper to start the thread, some don't. Nothing was harmed by this experiment. NPT/BSP are randomly interchangeable depending if the NPT was turned down to a small enough diameter. Neither are likely interchangeable with Metric.
/ Temp gauge #16
Actually, I would bet that Yanmar , Kubota, and other Japanese tractor makers use J I S, (Jananese Industrial Standard, aka BSPT), threads in all of their block fittings, (identical thread pattern and pitch as BSPT).
Thread Data Charts
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
207923 (A63290)
207923 (A63290)
2006 Freightliner M2 112 T/A Wet Kit Day Cab Truck Tractor (A66736)
2006 Freightliner...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
master diesel generator (A64553)
master diesel...
