Telescoping hydraulic rams
/ Telescoping hydraulic rams #1
Agent Blue
Platinum Member
Does anyone have a source for buying a two or three stage hydraulic ram that could be used for a dump trailer? I would like to build a trailer 6' x 10' with 3' sides and a capacity of 12-14k. Lifting from a reinforced front would work much better than the mechanisms commonly used nearly centered in the bed.
/ Telescoping hydraulic rams #4
If it was me, I would go to a truck salvage yard, if you are careful, you can buy the whole setup, for half what a new one will cost. Make sure you have the correct hydraulic source for the application.
/ Telescoping hydraulic rams #5
I'm with Willis. Telescoping cylinders are $$$...
/ Telescoping hydraulic rams #6
Yep, new ones are pricey. But, the old ones are in the salvage yard for a reason. Did you ever price rebuilding a telescopic cylinder? If you get a used one, be absolutely certain that it doesn't leak. Price of a used one plus price of a reseal equals more than a new one. Best part of buying new is that you get exactly what you need.
/ Telescoping hydraulic rams #7
Agreed Wayne. To clarify my previous post: I would look for a used dumping mechanism, meaning a normal cylinder scissor-type lift and then buy a new cylinder for it...
/ Telescoping hydraulic rams #8
My misunderstanding. You have to excuse me, I only have 2 brain cells left, and some days they don't speak to each other.
/ Telescoping hydraulic rams #9
Good luck finding a used scissor lift mechanism. It would be alot easier getting a regular ram but I know you want the scissor type.
Building one would be easier but finding prints for it would be next to impossible.
/ Telescoping hydraulic rams #10
I found a place that was wrecking old car carrier trailers and grabbed a couple of rams in a swap. They go to about 9' but I haven't got my project going yet. (Rams are still burried in the barn) I like the idea of a rams on each side, (since I have them). The geometry of the forces seems really weird but is supposed to work......
I have a ram and the scissors setup. The part I don't like is it puts so much stress on the center of the trailer, both dump and frame. I will have to check out sizes and how much of a reservoir it requires. At least I have a place to start. Thanks jr
/ Telescoping hydraulic rams #12
I am currently rebuilding the dump unit on my 1 ton truck. I am using 2 cylinders, mounted on the outsides of the frame rails. I like this better than the scissor setup. The cylinder grabs the dump unit further out creating a little more stability.
Parker Gravity Wagon (A66285)
Parker Gravity...
1999 Ford F800 Dump Truck, VIN # 3FEXF8019XMA05457 (A65563)
1999 Ford F800...
2018 Kubota SVL 75-2 Skidsteer (A65579)
2018 Kubota SVL...
New/Unused Wolverine 78in Quick Attach Rock Bucket (A65583)
New/Unused...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
1992 Fontaine Trailer 44ft (A62679)
1992 Fontaine...
