Dirt Moving Techniques To Leveling Dirt
/ Techniques To Leveling Dirt #21
Last spring I did about an acre. I tried a bunch of different things. My land is wavy. I tilled it first in three different directions. I ended up focusing on the high points and flattening them with my box blade then spreading outwards to try to push the material into the low spots. I tried a rake with only moderate success. I used a drag harrow in several directions to do the final smoothing and leveling. I'll be doing another two acres this spring. Hopefully I've learned something and it will take less time. You have to stay perpendicular to the high/low spots or you just propagate them.
Don't till it first. Just use the box blade and take it down and then spread the dirt and use the drag harrow.
/ Techniques To Leveling Dirt #22
First of all, don't push backwards unless it's soft dirt or snow -- the 3-point arms are not made to push. Doing that while attempting to cut into hard soil is a good way to bend/break your 3-point or bust the rear gearcase casting where the 3-point typically attaches. Plenty of threads here on TBN where people got into trouble doing this, some where the tractor was ruined when the gearcase was cracked open. I push backwards to clear snow with my rear blade, or to smooth soft soil with my box blade (with angle set to feather the cutting edges appropriately) but under no other circumstances. 3-point arms and their attachment points to the tractor are engineered to work under tension, not compression.
The box blade was invented to remove material from high spots and redistribute it to low spots. It can take a while to understand the box blade and longer to master it. Angle of attack is everything, and that is controlled by the top link. Shorten the top link to get more aggressive and dig, or lengthen it to smooth. Sometimes you have to adjust angle on the fly to get it right. A hydraulic top link makes it easy and really is the critical piece to making box blade work effective.
It's also important to use the float mode of your 3-point to keep the box blade in contact with the soil and independent of the tractor axles. If the box blade is raised out of float, it will move out of phase with the tractor -- front axle goes down, box blade goes up. Front axle goes up, box blade goes down. If you get into that situation, it's a great way to take a washboard surface and make it even worse. So make sure the box is down in float.
The box blade should be loading up with material when you go over high spots, and dropping the material into low spots. Again, angle of attack is key, and you may need to adjust on the fly to augment that process. Short toplink to dig and load up material, long top link to drop material and smooth/feather.
Sometimes it helps to make a couple rough passes doing this digging and redistributing, then make longer passes to smooth. Just depends on the size/spacing of the bumps relative to the size of the box blade. Also expect that the material you have scraped off high spots will be soft/loose when it drops into low spots, so compacting it with the tractor wheels and then making additional passes to complete the grading and smoothing may be required.
/ Techniques To Leveling Dirt #23
So Bmarshall1, why are you leveling 2 acres? Is it all loose soil or gravel?
s219 gave good advice. The only thing I would add is that if it swoops and divits, you can do well with a boxblade at slow speed and with a lot of action on the 3pt control. I'll say again that gauge wheels will do wonders. There's a reason road graders have long wheelbases and the blade is in the center. That is why I like my pony grader so much.
/ Techniques To Leveling Dirt #24
Some have mentioned this - don't push with your 3-point. Its designed to pull, not push. Hit something hard, a buried rock, and you could damage the 3-point, etc.
Using a rear blade requires a lot of experience. I've used my roll over box blade with success. It works best with the box blade in the float position. I've also used the tooth bar that is mounted on my FEL bucket. I use it in a dragging mode - bucket angled down, going in reverse. I also use my land plane grading scraper. It works best if the situation is more like ripples rather than long wave like variances.
Use the box blade if you need to move material from a high spot here to a low spot there.
You most likely will not get the land really level with just a couple passes. First go forward/back in north/south direction - then go forward/back in east/west direction.
/ Techniques To Leveling Dirt #25
I understand floating would improve flattening and if not it will move in relation to tractor wheels as you said, but why I have I not seen one single box blade dragged via a chain to completely avoid any tractor induced up or down movement?
I mentioned to a friend of mine that I wanted to build a box blade and he suggested I just use an old mattress spring after burning off foam or chain fence section. How do these cheap alternatives compare in finished result? I like the more refined look of a solid straight edged box blade and think the weight would assist in flattening compacted hills with grass and weeds on it. I already have an adjustable height dethatcher with wheels and thinking I could skip the box blade teeth and just build a heavy steel box then drag it with a short chain right off the back of the dethatcher. If an angle is wanted, just change the length of chain on one side. Wouldn't this route theoretically give just as good if not better results and much much cheaper cost?
/ Techniques To Leveling Dirt #26
...why I have I not seen one single box blade dragged via a chain to completely avoid any tractor induced up or down movement?
Probably because it won't work. You can't adjust the vertical angle if pulled with a chain. It would just flop around, and you couldn't use the rear blade to pivot on to adjust the cut of the front blade.
The mattress or chain link fence will smooth the surface but not do any real leveling.
Bruce
/ Techniques To Leveling Dirt #27
I understand floating would improve flattening and if not it will move in relation to tractor wheels as you said, but why have I not seen one single box blade dragged via a chain to completely avoid tractor induced up or down movement?
The Ferguson Three Point Hitch is a marvelous invention. Developed in the 1920's in England and Ireland, now standardized all over the world, it unitizes the tractor and implement.
Some of the implement weight is transferred to the tractor chassis, improving traction, optimally when 4-WD is employed.
Before the Three Point Hitch, light tractors weighed six tons.
Prior to Ferguson's invention implements, mostly moldboard plows, were drawn by chains. It required at least six tons of tractor weight for tractive power sufficient to move a two bottom plow pulled with chains.
/ Techniques To Leveling Dirt #28
For the higher 'bumps', back dragging with my toothed bucket at a tight angle works great for me.
It also separated vegetation roots etc in preparation for finish.
Sort of like a shallow disk harrow would accomplish.
/ Techniques To Leveling Dirt #29
Two ares will take a while and it will take more than 2 passes. It depends on weather you are making a parking lot or a nice yard as how you move the topsoil. Scrape all the topsoil and try to grow grass and you will hate yourself. The box blade with rippers is your tool of choice. You won't use your loader much until the very end when you back drag.
/ Techniques To Leveling Dirt #30
Also - I've learned to love the long-period rolling nature of a lot of my fields. I can smooth that, plant it and it works. Even if the two acres is going to be a lawn - no need for it to be flat like a pool table.
/ Techniques To Leveling Dirt #31
Is the lot freshly cleared? If so dealing with the roots is harder than actually leveling it.
/ Techniques To Leveling Dirt #32
It would be nice if the OP would come back on, describe in more detail his project, and maybe include some pics.
/ Techniques To Leveling Dirt #33
GAUGE WHEELS!
If doing more or less straight runs, I will use the 3 point angle blade and set angle at 45 and do passes down the road and that will usually shave off the high spots and then reverse angle to other side and roll the material back in the other direction.
If trying to do leveling in field I use the box scraper with the rippers just barely touching the ground when level and use that to hit the mounds and tops of humps.
For pads I angle the blade closer to straight then 45 with the outward edge slightly higher and start in center of pad and drive in a outward spiral circle casting the excess dirt outward and have had good results that way.
David
Draging a heavy timber works.
/ Techniques To Leveling Dirt #34
I've had a fair amount of success using a box blade on the 3 point and floating it rather than keeping it at a fixed height relative to the tractor.
My Kubota doesn't have a detent on the 3 point control like the FEL does, so I usually just hold it down or use a bungee if I'm doing a lot of
grading.
Floating the blade keeps it from digging in when the tractor pitches on the rough ground. Perhaps you could do something similar with your
back blade?
I know there are some 3 point hitches made with down pressure, but I have never had one on a tractor.
The ones that I have used have a built in mechanical float. Just hold the lever down until you hear the relief valve open, let go, the attachment can then freely move up or down throughout the travel of the lift arms.
You can test yours with no attachment on the 3 point, hold the lever down until you hear the relief valve open, let go, then grab the end of a lift arm and pull up, both will raise to the upper limit and not stay there.
/ Techniques To Leveling Dirt #35
I have had good luck using a landscape rake while driving in random circles. As others have mentioned, the length of the top length greatly affects the grading action. However, most important is that the rake needs wheels. And the ground needs some moisture in it.
/ Techniques To Leveling Dirt #36
Again, Gauge Wheels make a huge difference.
Hey Guys - thanks for all the great replies. Here's a little more info... on a newly purchased home in SW Florida the soil runs from very sandy and loose to hard pack marle (sp?) of almost a concrete consistency. We had about 2 of 4 ares cleared with a giant bobcat mounted grinder. There is a lot of roots and ground down stumps from the clearing efforts. I purchased a RR to drag the 'mulch' into low spots and will be eventually bringing in some top soil and that's what will be needing leveled. I will likely not try to level the current ground except for the really high spots.
It's a Hawse bx bade with front and back blades but no rakes. The high to low spots may only be about 2-3 feet difference over the course of 30 feet, more wavy and rolling than anything else, if I can figure out how to add pix I will do so. I like the angle blade idea and starting on a small flat spot, of going in circles or fig. 8's.Te 3 point has lower 'dogleg' links kept from swinging around by 2 turnbuckles (no hydro top link).
/ Techniques To Leveling Dirt #38
That is helpful information. Attach pics later if you can. I am guessing your box blade is set up for scarifiers, even it they are missing. They aren't all that expensive to buy from places like Rural King, Tractor Supply, etc. I think they would really help you with your project.
/ Techniques To Leveling Dirt #39
find your neutral position for the box blade so its not going down all the time. set you down feed speed to slow so once the bo goes over a high spot it will stay up longer as you drive over the low spot dumping what it picked up from the high spot into the low spot. see my video on the box blade here. THE BOX BLADE - YouTube
and my latest video on leveling the three point hitch here how to level your three point hitch the easy way! - YouTube
/ Techniques To Leveling Dirt #40
Only on plowed or rototilled ground, if it has not been disturbed then the clay will need to be shaved down here, the heavy timber will just bounce around. The box scraper requires the ripper to be dropped to rip the ground otherwise cutting is minimal.
David
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2025 JMR 8ftx4ft Safety Basket Skid Steer Attachment (A66734)
2025 JMR 8ftx4ft...
CAT 953C Cab (A68134)
46901SFL (A64557)
46901SFL (A64557)
ALLMAND ECO-LED LIGHT PLANT (A68842)
ALLMAND ECO-LED...
