Rotary Cutter Tebben 40"
/ Tebben 40" #1
Richgvt
Vermont
Kubota BX23
I had asked a couple of weeks ago if anyone knew about Tebben rotary cutters. There is one available that I found for sale. It is a 40". 42" is recommended for my Kubota BX23 although 48" will work. Do you think a 40" would be ok size wise. It will be a little narrower than the width of the tires. I assume it will fit. I just bought the tractor so I'm new to all the 3 point hitch stuff. Any thoughts would be appreciated. I have 5 acres and just trying to cut down brushy areas and maintain what is not lawn. I will have to cut down some of the larger stuff first.
/ Tebben 40" #2
Personally, I'd never even heard of Tebben Rotary Cutters but see they have a website. A 40" one should serve you well unless you need to get close to buildings, fences, and such. I always preferred a rotary cutter a few inches wider than the outside of my rear tires for that reason.
/ Tebben 40"
That would not be a problem. Getting close to trees would be the only problem but no big deal.
/ Tebben 40" #4
We have 1 New big Bee 4 ft for $695 + shipping left at last years pricing.. Can figure shipping with your zip code? Ken Sweet
/ Tebben 40"
The one I saw advertised is $300. It is used. New is out of my range right now
2023 Dodge Ram Crew Cab - Built to Serve Edition (A66408)
2023 Dodge Ram...
2015 PETERBILT 579 (A65643)
2015 PETERBILT 579...
2016 KENWORTH  W900 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
