Ballast TC55 Rear Ballast
   / TC55 Rear Ballast #1
deerhunterf350
St. Louis, Mo
New Holland TC55DA
Thinking about a 55 Gallon Drum filled with Concrete for Ballast on the 3PH. Anyone have an Idea what a Drum of Concrete will way.
If I knew anyone in the MOB , I'm sure they would know the exact weight of a Drum full of Concrete.:D :D :D
   / TC55 Rear Ballast #2
Concrete is about 150lbs per cubic feet. 55 gal * 0.13368 cf/gal = 7.3524 cf in a full barrel. So 55 gal of concrete is 1,103 lbs. Add to that the weight of the barrel & mounting hardware say 50 lbs = 1,153 lbs.
   / TC55 Rear Ballast
Thanks TwinWillows,
I am sure that will be more than enough Ballast.
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
1988 FONTAINE TRAILER CO. 50 STEP DECK LOADER TRAILER (A58214)
1988 FONTAINE...
2022 BOBCAT E60 R2-SERIES EXCAVATOR (A52709)
2022 BOBCAT E60...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
