Ballast TC55 Rear Ballast
   / TC55 Rear Ballast #1
deerhunterf350
St. Louis, Mo
New Holland TC55DA
Thinking about a 55 Gallon Drum filled with Concrete for Ballast on the 3PH. Anyone have an Idea what a Drum of Concrete will way.
If I knew anyone in the MOB , I'm sure they would know the exact weight of a Drum full of Concrete.:D :D :D
   / TC55 Rear Ballast #2
Concrete is about 150lbs per cubic feet. 55 gal * 0.13368 cf/gal = 7.3524 cf in a full barrel. So 55 gal of concrete is 1,103 lbs. Add to that the weight of the barrel & mounting hardware say 50 lbs = 1,153 lbs.
   / TC55 Rear Ballast
Thanks TwinWillows,
I am sure that will be more than enough Ballast.
Heavy Duty Skid Steer Post Driver (New/Unused)(Est. Retail Value $4,900). (A59225)
Heavy Duty Skid...
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2008 IC Corporation PB105 School Bus (A55973)
2008 IC...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
