Ballast TC55 Rear Ballast
   / TC55 Rear Ballast #1
deerhunterf350
St. Louis, Mo
New Holland TC55DA
Thinking about a 55 Gallon Drum filled with Concrete for Ballast on the 3PH. Anyone have an Idea what a Drum of Concrete will way.
If I knew anyone in the MOB , I'm sure they would know the exact weight of a Drum full of Concrete.:D :D :D
   / TC55 Rear Ballast #2
Concrete is about 150lbs per cubic feet. 55 gal * 0.13368 cf/gal = 7.3524 cf in a full barrel. So 55 gal of concrete is 1,103 lbs. Add to that the weight of the barrel & mounting hardware say 50 lbs = 1,153 lbs.
   / TC55 Rear Ballast
Thanks TwinWillows,
I am sure that will be more than enough Ballast.
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
3PT HAY FORK (A52708)
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
