TC45D Cruise Control Problem
   / TC45D Cruise Control Problem #11
I have a similar issue. It seems that the magnet doesn't hold as well as it did when new. When energized with 12 volts, it magnetizes, but I can pull it off relatively easily. It does have a bit of crud on the surface, but doesn't seem to me to be enough for it to slip. Is there a way to measure the holding power and if so, is there a spec for this?
   / TC45D Cruise Control Problem #12
If you checks its impedance the manual says it should read 11-12 ohms.
david
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
