TC45D Cruise Control Problem
   / TC45D Cruise Control Problem #11
I have a similar issue. It seems that the magnet doesn't hold as well as it did when new. When energized with 12 volts, it magnetizes, but I can pull it off relatively easily. It does have a bit of crud on the surface, but doesn't seem to me to be enough for it to slip. Is there a way to measure the holding power and if so, is there a spec for this?
   / TC45D Cruise Control Problem #12
If you checks its impedance the manual says it should read 11-12 ohms.
david
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
UNUSED FUTURE D39 39" HYD TRENCHER (A57193)
UNUSED FUTURE D39...
2006 Ford Explorer 4x4 SUV (A55853)
2006 Ford Explorer...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
