TC45D Cruise Control Problem
   / TC45D Cruise Control Problem #11
I have a similar issue. It seems that the magnet doesn't hold as well as it did when new. When energized with 12 volts, it magnetizes, but I can pull it off relatively easily. It does have a bit of crud on the surface, but doesn't seem to me to be enough for it to slip. Is there a way to measure the holding power and if so, is there a spec for this?
   / TC45D Cruise Control Problem #12
If you checks its impedance the manual says it should read 11-12 ohms.
david
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
2023 TAKEUCHI TL10V2 SKID STEER (A52707)
2023 TAKEUCHI...
