TC40DA Blows #5 Fuse After 15-30 Minutes
   / TC40DA Blows #5 Fuse After 15-30 Minutes #1
dakota52
Savannah, MO
New Holland TC 40 DA
My New Holland TC 40 DA has started blowing the 7.5 amp number five fuse. This takes out my high speed range (rabbit/turtle switch) and cruise control. The tractor starts fine and will run 15-30 minutes before the fuse blows. I have looked for a frayed wire but haven't found any. I tried changing the high range shift relay and that hasn't helped. Can the diode be bad? I will appreciate anybody's suggestions. This is getting very frustrating. Up until now the tractor/cab had been fine.
   / TC40DA Blows #5 Fuse After 15-30 Minutes #2
The chance of a diode pack being bad is very slim. Much more likely is a faulty cruise control magnet under the right-side operators platform or the range solenoid on the left side of your transmission under the left operator's platform. Have you checked wiring there? The wires to the rabbit/turtle solenoid are very exposed.
If you are not using cruise, then the cruise magnet is likely NOT the problem. Fuse 5 also supplies alternator excitation voltage. Does your alternator seem to work okay? If there is a problem with the alternator, the light on the instrument panel should illuminate.
The alternator seems to work fine and the dash light isn't on. It did it again this morning and I didn't even have cruise on. How do you access the wiring under the rabbit /turtle switch? Do I have to remove the right rear tire to gain access? I can't figure out how to get the panel off under the cruise switch and rabbit/turtle switch. Thanks for help and suggestions.
   / TC40DA Blows #5 Fuse After 15-30 Minutes #4
There are bolts for the right side panel under the fender and you do not have to remove the tire to get to them. Also, there is a connector for the joystick rabbit/turtle switch under the rubber boot of your joystick.
Does the fuse blow only when you are in rabbit? The solenoid for the speed control is under the left operator's platform and is energized only when you shift to rabbit speed. If the fuse blows in rabbit, but not in turtle, then the problem points to the solenoid or its wiring. The diodes for rabbit/turtle only function to aid switching. If you can switch from rabbit to turtle and back, then the diodes are good. I think you have a wire rubbing or chewed by a critter somewhere.
I am heading out to the shed to check both the wiring again and the range solenoid. I will let you know what we find. Thanks so much. This is a frustrating problem.
I checked the wiring near my range solenoid and didn't find any breaks in the insulation. I had to reconnect the wires to the solenoid a few years back and at that point I covered them with wire loom to protect them. I pulled the solenoid coil and put it on a battery for about an hour to see if the resistance changed. The resistance started out at 10.0 ohms and was 14.2 ohms after an hour. So it doesn't look like the solenoid is heating up and drawing too much current.
My plan tomorrow is to run the tractor in cruise without the coil installed and see if the fuse blows. If it doesn't, then I will flip the rabbit/turtle switch to rabbit and see if I can run for more than 30 minutes without blowing the fuse. I will also check the wires to the alternator and see if I find anything there. Hopefully something will show up. Thanks again for the help.
I ran the tractor the other day without the range solenoid coil installed to see if I still blew fuse #5. What I found was that without the coil installed I still blew the fuse about 30 minutes (consistent with what I have been seeing) after pushing the rabbit/turtle switch to rabbit. If I left the switch in turtle I never blew the fuse. I also tried running my cruise control and never blew the fuse with cruise on as long as I stayed in turtle. Because there is a consistent amount of time between fuses blowing I think a part is getting hot with time and drawing too many amps blowing the fuse. At least I now know it isn't the range solenoid which is a pricey part!
I re-checked all the wiring from the #5 fuse to the range solenoid and to the rabbit/turtle switch on the fender today. Thank you to jinman for the advice on how to access the fender rabbit/turtle switch. I also checked the wires to the alternator. I didn't find any breaks in the wires. I didn't remove the black braided protector from the harness and hope that my problem doesn't lie with a wire rubbing inside there.
I am starting to wonder if my rabbit/turtle switch is causing my problem. Does anyone know how to test the switch? Could it be heating up when in rabbit mode and the drawing too many amps causing the #5 fuse to blow? I noticed when I removed the switch that there were a lot of wires connected to it. I expected a SPDT toggle switch with 3 wires (common +12V, rabbit, turtle) so I am confused about what the extra wires are doing. I appreciate any help that is offered. At least I can use the tractor in turtle mode for now.
   / TC40DA Blows #5 Fuse After 15-30 Minutes #8
A while back, I posted the details of how the Rabbit/Turtle circuit works in this thread. I should have sent you to the thread before, but didn't think of it until now. With your detailed info in your last post, I think we can make some analysis and eliminate a couple of things.
You said you replaced the hi-shift relay. That leaves the low-shift relay, but all it does is provide ground for the high-shift relay coil. If it were grounding out, the circuit would not care since its function is to provide ground anyhow. With that info and your troubleshooting, all that's left is the diode pack, switches, and wiring. You can eliminate the joystick switch by disconnecting it and using only the fender switch. The contacts of the fender switch are open after you set Rabbit, but power comes to the light bulb for Rabbit.
The same power that holds the range solenoid powered is fed through the latch diode to hold the hi-shift relay coil energized. It's ground path is through the low-shift relay contacts to ground (see slide #3 in the linked thread, 1st post). The diodes are in the same general location as the relays under the cowling on the left side below the steering wheel. A diode pack contains both diodes. If one of those is heating up and shorting to ground, it could cause the problem because the diode is before the hi-shift coil and that would pop the fuse.
I know you wondered about this diode pack in the beginning and I played it down, but I think you should probably go ahead and replace it based on your excellent troubleshooting. You just can't troubleshoot something that works for 30 minutes and then shorts out internally unless you feel the heat or see burn marks or smell odor. I know it's a bit of an Easter egg hunt, but if your wiring is all good and not mouse chewed, I think changing that diode pack is the next move.
jinman,
Thanks yet again for the response and help. I don't want to sound like I am questioning you, since you are definitely an expert on tractor electronics, but can you please double check something for me. I am not sure that the diode pack can short to ground. I reviewed the wiring diagram in my owner's manual and only see hot (12V) wires going to/from the diode pack and no grounds. Without a ground somewhere in the pack I don't think it could short internally. I may be missing something here so if you would please check this for me I would appreciate it. I can send a copy of my wiring diagram if you need it.
I now understand all the wires for the rabbit/turtle switch. The extra ones are for the lights that turn on to indicate which speed is active. Everything looks good on that switch since the lights activate correctly so I don't think the switch is shorting and blowing the fuse. I don't have a FEL or joystick (should have mentioned that earlier) so I don't have to worry about that.
When I looked deeper into the wiring diagram I noticed that fuse #5 also powers the park brake relay coil. I think I will try swapping this relay with a different one and see what happens. I also noticed that fuse #5 powers a wire going to the instrument panel that is labeled "SW B+". I assume this means "switched battery positive"? I am not sure how the instrument panel routes this power so there may be additional circuits coming out of the instrument panel that I haven't considered that are also powered by fuse #5. I may have to pull the instrument panel and see if I can tell how everything connects if I don't find my problem elsewhere. Thanks in advance for any help that is offered.
   / TC40DA Blows #5 Fuse After 15-30 Minutes #10
You are correct. The one and only way the diode pack could be blowing the fuse is if it's shorted to the case and that's grounded through the mounting screw or the case is grounded. It could also be the socket. I believe from the parts diagram that the diode modules are plugged into a socket like relays. The real point I'm trying to make is that to blow the fuse, it has to be a short to ground before any relay coil. Since you replaced the hi-shift relay, there is no way the lo-shift relay can cause the problem. Of course, there is the high shift relay's socket. . . see what I mean?
Trying to troubleshoot through a forum has lots of problems. I'm a hands-on guy in a decidedly hands-off environment. That said, didn't you just post that no fuse blew if you just left the transmission in turtle? If so, it would seem a bit off target to go looking for other sources of a short. Surely if there is no fuse blown in turtle, it is related to something in the hi-shift circuit. Does that make sense?
jinman,
Thank you for help and patience in helping me troubleshoot my problem. I feel your pain about troubleshooting from a distance. I am often asked to call customers at work (we make electric/hydraulic vehicle lifts) to see if I can help them get their equipment back up and running. The most frustrating part is knowing that if I was there in person I could probably find the problem 10X faster than having to work over the phone.
You are right that I am getting off track to look at components outside the hi-shift circuit. I do not blow the #5 fuse unless the transmission is in rabbit so it must be in that circuit. I guess the frustration of chasing this problem got me moving too fast and not thinking things through. I will pull the diode pack in the next couple of days. If it looks suspicious at all I will order a new one and let you know if that fixes things. You are right that the diode pack plugs into a socket just like the relays near it. I will also look over the high shift relay socket and see if I notice anything there. I appreciate the help in knowing where to look.
I pulled the diode pack off the tractor the other day and ordered a new one. It was marked "Dill Blox 100690" on the outside of the plastic case. I was a little shocked to see that the dealer wanted $67 for such a simple looking part. I decided to see if I could source the part elsewhere and found it for only $15 at Dill Blox Diode Module 100690 6A 1000V 100685 100686. They had about 150 of them available so it looks to be a reliable source of this part. I should receive the diode pack later this week and will try it out once it arrives and then post an update
I also wanted to let everyone know that I found a good alternative range solenoid coil instead of spending $450+ at the dealer for the whole range solenoid assembly (I still can't believe they don't offer just the coil and make you buy the whole thing). I had started researching this a couple of weeks ago and was glad when I found out that the range solenoid coil wasn't causing my fuse to blow. I figured since I had a couple of coils that looked like they would work I would go ahead and try them and report what I found. I borrowed a HydraForce 6352012 coil from work to see how it fit and worked. I installed it on my tractor today and it fit and worked perfectly. It shifted fine and I didn't notice any difference between it and the factory original. I checked the resistance of the coil and it checked at 7.2 ohms so it is pretty close to the original one on that as well. The best part is that I found the coil available on the web from several sources such as http://www.hydraulicstore.com/index.php?loc=items_detail&data[history]=&data[catalog]=1&data[itemcode]=7014959 for under $20. The only modification required to use this coil is that you have to leave off the metal case that goes over the original. So it may not be quite as well protected, but for the price you can buy an extra coil and still come out way ahead.
Good news. I got my new diode pack the other day and put it in. So far I have run the tractor about 3 hours in rabbit and have not blown the fuse. So it looks like my problem is solved. Jinman, thanks a bunch for your help with this.
   / TC40DA Blows #5 Fuse After 15-30 Minutes #14
Great news Tom, and thank you for the info on a bargain source for the parts.:) It's amazing how much money you can save by shopping the web.
I know it has been a while since I last posted on this thread, but I wanted to post an update on my TC-40DA (Hopefully this doesn't break a rule about posting on old threads). After replacing the diode pack the tractor did not blow the #5 fuse for a few weeks. However, the weather cooled off here during that time and I was working without the A/C on. When it heated up again and I was using the A/C I started blowing the fuse again after about the same 15-30 minutes of use.
I finally found that the problem all along was a couple of wires with damaged insulation. The wires are located under the hood near where the two large plugs pass through the firewall from the cab (on the right side of the tractor as you sit in the seat). The wires are close to some A/C lines and when the A/C ran condensation collected on the damaged wires allowing them to short to one another. After repairing the wires and putting all of the wires in that area in some loom the problem has gone away for good. I am really glad this problem is solved. Just wanted to let everyone know how I finally fixed this problem in case anyone else is fighting the same thing.
   / TC40DA Blows #5 Fuse After 15-30 Minutes #16
Tom, it would be interesting to know what those wires are going to since they must pull power from fuse #5. Since I don't have a "with-cab" schematic, it's a mystery to me. Perhaps the power is to lighting inside the cab.
Jim,
The wires are going from the relay block under the steering wheel out to the high range shift solenoid coil. They pass thru the firewall on the right side (almost directly behind the relay block) in one of two large round plugs. So it made sense that the fuse would only blow when the rabbit/turtle switch was on rabbit since that was the only time this wire had power to it. It took a combination of the rabbit switch being on and the A/C causing condensation on the wires to blow the fuse.
   / TC40DA Blows #5 Fuse After 15-30 Minutes #19
Dakota, my New Holland does the exact same thing only blows fuse in 2 minutes. Have taken it to dealer many times which helped it for a few days and it starts all over. Did you ever figure out what your problem was? docyandell
The AC water condensation was shorting out under the hood where the AC lines and wires go into the cab firewall on the right side. It was barely a nick in one wire where it went thru the cab firewall that caused the trouble. A simple wrapping of waterproof electrical tape over the wire group solved the problems. However, it caused many grey hairs before the headache was found. Good luck on finding your short!
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
VOLVO ECR25...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
