Tc40 front axle venting
   / Tc40 front axle venting #1
nyone
Elite Member
Ford 851
my 2001 tc40 with 3100hr was parked for about 2 days when we had a major warm spell (20* to 60* and sunny) well my axle seal started leaking. It had been sitting there for 2 days before it started leaking. I opened the dip stick and cleaned off the leaking axle. The leak has stopped and the fluid is full. This has lead me to believe that I need a vent.
I know the JD guys have vented dip sticks available..do the NH guys?
   / Tc40 front axle venting #2
Is there a fill plug / something on the opposite side from the dip stick? I kind of remember a large port and a small port on each side when I used to do tractor pre deliveries.
Unfortunately theres not. Just the dip stick.
   / Tc40 front axle venting #4
I would be tempted to remove the dipstick and put in a breather there then. Possibly make a dipstick of the same length on whatever breather you end up with.
   / Tc40 front axle venting #5
might call your dealer service dept & describe the issue. also after a long workout, pull the dipstick to see if any pressure built up.
also read where 80/90 gear oil is more forgiving than UDT for axle leaks, but can't confirm as i've had no issues w/mind, regards
This is definitely 80/90 gear oil. Anyone know if the stick needs to be screwed in to check the level on the stick? If so I'm about 1/2in over filled.
   / Tc40 front axle venting #7
I've often wondered this question as well about dip sticks which thread into a hole. I have read manuals that say you screw while others say to rest it on the threads, couldn't be more confusing.
The manual for my TC33D says the following:
NOTE: To obtain correct oil level reading
do not screw dipstick into axle housing
when checking oil level.
  • TC33D Front Drive Oil Level.pdf
Thank you. I looked high and low in the digital tc40 manuals I have and couldn't find anything like that.
This confirms my level is correct.
   / Tc40 front axle venting #9
I'll confirm that the instructions on my model, TC29DA, are also to read the stick without screwing in.
My change instructions are to use hydraulic fluid.
   / Tc40 front axle venting #10
If you screw the stick in, it would seem that it would be impossible to read the level accurately because with gear oil especially (thick) the screwing in/out would act as a paddle/blender action that would pull/wick the fluid up the stick and give a false reading
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
2020 Deere 325G (A50123)
2020 Deere 325G...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
