Tc40 front axle venting
   / Tc40 front axle venting #1
nyone
Elite Member
Ford 851
my 2001 tc40 with 3100hr was parked for about 2 days when we had a major warm spell (20* to 60* and sunny) well my axle seal started leaking. It had been sitting there for 2 days before it started leaking. I opened the dip stick and cleaned off the leaking axle. The leak has stopped and the fluid is full. This has lead me to believe that I need a vent.
I know the JD guys have vented dip sticks available..do the NH guys?
   / Tc40 front axle venting #2
Is there a fill plug / something on the opposite side from the dip stick? I kind of remember a large port and a small port on each side when I used to do tractor pre deliveries.
Unfortunately theres not. Just the dip stick.
   / Tc40 front axle venting #4
I would be tempted to remove the dipstick and put in a breather there then. Possibly make a dipstick of the same length on whatever breather you end up with.
   / Tc40 front axle venting #5
might call your dealer service dept & describe the issue. also after a long workout, pull the dipstick to see if any pressure built up.
also read where 80/90 gear oil is more forgiving than UDT for axle leaks, but can't confirm as i've had no issues w/mind, regards
This is definitely 80/90 gear oil. Anyone know if the stick needs to be screwed in to check the level on the stick? If so I'm about 1/2in over filled.
   / Tc40 front axle venting #7
I've often wondered this question as well about dip sticks which thread into a hole. I have read manuals that say you screw while others say to rest it on the threads, couldn't be more confusing.
The manual for my TC33D says the following:
NOTE: To obtain correct oil level reading
do not screw dipstick into axle housing
when checking oil level.
  • TC33D Front Drive Oil Level.pdf
Thank you. I looked high and low in the digital tc40 manuals I have and couldn't find anything like that.
This confirms my level is correct.
   / Tc40 front axle venting #9
I'll confirm that the instructions on my model, TC29DA, are also to read the stick without screwing in.
My change instructions are to use hydraulic fluid.
   / Tc40 front axle venting #10
If you screw the stick in, it would seem that it would be impossible to read the level accurately because with gear oil especially (thick) the screwing in/out would act as a paddle/blender action that would pull/wick the fluid up the stick and give a false reading
2012 Ford Explorer (A53317)
2012 Ford Explorer...
DIRT DOG BBX72 72" BOX BLADE (A57192)
DIRT DOG BBX72 72"...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
2014 Chevrolet Traverse 2LT SUV (A55853)
2014 Chevrolet...
2000 Triton boat with trailer (A55853)
2000 Triton boat...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
