Oil & Fuel TC33DA Leaking Oil
   / TC33DA Leaking Oil #11
I believe I noticed the small puddle after about 100 hours; I now have close to 400 hours on the tractor. Itエs funny in that it doesn't consistently produce the small 1-2" puddle. For instance, when I took the picture there was no sign of a puddle and the tractor has been parked in the same place for more than a week. I'll keep an eye on it, but I guess I'm hoping as long as it doesn't grow into something that I need a yard stick to measure I'm ok.
   / TC33DA Leaking Oil #12
Just pray it does not let go and empty the contents onto the grass as you are working it and you do'nt notice the slick . I put up with a couple of drips from my 1942 Massey Harris but would not from a near new tractor with those low hours on it .
   / TC33DA Leaking Oil #13
If his HST pukes it's oil out.. he won't have to 'notice' the slick.. the sucker just won't move anymore...
soundguy
   / TC33DA Leaking Oil #14
thclimer said:
I believe I noticed the small puddle after about 100 hours; I now have close to 400 hours on the tractor. Itï½´s funny in that it doesn't consistently produce the small 1-2" puddle. For instance, when I took the picture there was no sign of a puddle and the tractor has been parked in the same place for more than a week. I'll keep an eye on it, but I guess I'm hoping as long as it doesn't grow into something that I need a yard stick to measure I'm ok.
If your at 400 hours now and it hasn't gotten any worse, good chance it'll be fine. Some seals have a tendency to sweat a little. Component tolerances and temperature can also affect the frequency/severity of a leak.
If it was mine, I might give that cotter pin a twist every now and the just to be sure the ~sweat~ isn't collecting dust and clogging the hole. This way I'd know for sure if it was something to worry about.
   / TC33DA Leaking Oil #15
soundguy
Yes and in the 60 seconds that he is sitting there wondering why it wont move with the engine running he will have fried the trans $$$$$$$$.
2021 Ford F-250 4X4 Crew Cab Pickup Truck (A55973)
2021 Ford F-250...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2002 FREIGHTLINER FLD 132 SLEEPER TRUCK (A58018)
2002 FREIGHTLINER...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
