Oil & Fuel TC33DA Leaking Oil
   / TC33DA Leaking Oil #11
I believe I noticed the small puddle after about 100 hours; I now have close to 400 hours on the tractor. Itエs funny in that it doesn't consistently produce the small 1-2" puddle. For instance, when I took the picture there was no sign of a puddle and the tractor has been parked in the same place for more than a week. I'll keep an eye on it, but I guess I'm hoping as long as it doesn't grow into something that I need a yard stick to measure I'm ok.
   / TC33DA Leaking Oil #12
Just pray it does not let go and empty the contents onto the grass as you are working it and you do'nt notice the slick . I put up with a couple of drips from my 1942 Massey Harris but would not from a near new tractor with those low hours on it .
   / TC33DA Leaking Oil #13
If his HST pukes it's oil out.. he won't have to 'notice' the slick.. the sucker just won't move anymore...
soundguy
   / TC33DA Leaking Oil #14
thclimer said:
I believe I noticed the small puddle after about 100 hours; I now have close to 400 hours on the tractor. Itï½´s funny in that it doesn't consistently produce the small 1-2" puddle. For instance, when I took the picture there was no sign of a puddle and the tractor has been parked in the same place for more than a week. I'll keep an eye on it, but I guess I'm hoping as long as it doesn't grow into something that I need a yard stick to measure I'm ok.
If your at 400 hours now and it hasn't gotten any worse, good chance it'll be fine. Some seals have a tendency to sweat a little. Component tolerances and temperature can also affect the frequency/severity of a leak.
If it was mine, I might give that cotter pin a twist every now and the just to be sure the ~sweat~ isn't collecting dust and clogging the hole. This way I'd know for sure if it was something to worry about.
   / TC33DA Leaking Oil #15
soundguy
Yes and in the 60 seconds that he is sitting there wondering why it wont move with the engine running he will have fried the trans $$$$$$$$.
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
2007 Mercedes Benz S550 (A56859)
2007 Mercedes Benz...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
Rhino DB150 (A57148)
