TC33DA - bent 3 point hitch arm
   / TC33DA - bent 3 point hitch arm #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
I hit a stump and bent the left side 3 point hitch arm on my TC33DA :(. Photos attached.
I seem to recall that it originally had a slight bend in it, but perhaps not? The right arm does have a slight bend.
I'm looking for either photos or a description of what is a "normal" bend, if any, for this arm.
Thanks,
Tom
   / TC33DA - bent 3 point hitch arm #2
Just from the parts diagram it looks like it bent in the middle.
OK, thanks. Then I must have slightly bent the other lift arm as well :(.
   / TC33DA - bent 3 point hitch arm #4
Sorry for what happened to your rig. Glad you are ok. If it were my rig, then I would try to repair to some working condition. I would heat it up red and straighten it up in a hydraulic press. Obviously, you would loose the temper and the metal becomes more malleable and soft doing so. I would then heat it up red hot and quench it in oil or water to harden. I then heat it up, not red hot and let it air cool to temper and add more toughness. After all of that, I would prep the area and weld up a piece of flat 2"x8" flat 1/2" or 3/8" thick steel plate on either side like a metal splint. I would then clean it up and paint. It ain't going to be pretty but will function about the same. Alternately NH would love to sell you lower control arm for $$$$.
   / TC33DA - bent 3 point hitch arm #5
I would agree with the press idea, but not the heat. I have straightened a few of them, always bent them cold. You can heat it if you like, but I wouldn't suggest for someone to do that.
Your tractor, your money, your choice.
   / TC33DA - bent 3 point hitch arm #6
I hate to heat it as well, but it is going to be tough to straighten unless you have a very heavy duty press. I brought up heat treatment so one could get it as close to original metal condition along with welding up splint.
   / TC33DA - bent 3 point hitch arm #7
If it is still available.
   / TC33DA - bent 3 point hitch arm #8
Long lane tractor in Elizabethtown PA. is a NH wrecking yard they probably have them.🍻
   / TC33DA - bent 3 point hitch arm #10
From my TC33D manual, it pretty much shows the only bends are near each end:
2015 Jeep Cherokee Latitude SUV (A53424)
2015 Jeep Cherokee...
2017 TRAVIS BODY & TRAILER END DUMP (A55745)
2017 TRAVIS BODY &...
2012 Ford F-350 (A53314)
2012 Ford F-350...
1986 Value 40' Drop Deck (A53314)
1986 Value 40'...
2016 NISSAN VERSA Sedan (A55758)
2016 NISSAN VERSA...
23'x22' Double Garage Metal Shed (A53316)
23'x22' Double...
