Tc33d injection pump
/ Tc33d injection pump #1
ajortega
New holland tc33d
I had my injection pump rebuilt and now it wont idle or run .....was running fine then rebuilt and I bypass fuel solenoid and start it and wit a magnet I can stick to fuel rail and keep it running but throttle sometimes works sometimes it dont.....
/ Tc33d injection pump #2
By chance did u bend the engine control rack that slips over the pin on the pump rack.?? {most likely cause}
Did u test the pump by moving the rack back & forth BEFORE u installed it.?? if so.. see above.
IF the rack was free/slides freely back & forth OUTSIDE of the engine.. & wont INSIDE the engine.. its an engine/installation problem..
Did YOU install it.??
Yes I installed it..removed it carefully and I dont believe I bent it I just ordered shim kit I only had 1 on it from previous owner super thin...so I bolt it done and governor keeps it shut off ...I raise it and somewhat loose on bolts and it fires up and idles now.......but there is a gap
Also should the linkage move when pump is out or motor has to be running
2019 CATERPILLAR 316FL EXCAVATOR (A65053)
2019 CATERPILLAR...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A64556)
2010 Workhorse...
213085 (A64276)
213085 (A64276)
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
Ground Protection Mats (A64194)
Ground Protection...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
