Tc33d injection pump
/ Tc33d injection pump #1
ajortega
New holland tc33d
I had my injection pump rebuilt and now it wont idle or run .....was running fine then rebuilt and I bypass fuel solenoid and start it and wit a magnet I can stick to fuel rail and keep it running but throttle sometimes works sometimes it dont.....
/ Tc33d injection pump #2
By chance did u bend the engine control rack that slips over the pin on the pump rack.?? {most likely cause}
Did u test the pump by moving the rack back & forth BEFORE u installed it.?? if so.. see above.
IF the rack was free/slides freely back & forth OUTSIDE of the engine.. & wont INSIDE the engine.. its an engine/installation problem..
Did YOU install it.??
Yes I installed it..removed it carefully and I dont believe I bent it I just ordered shim kit I only had 1 on it from previous owner super thin...so I bolt it done and governor keeps it shut off ...I raise it and somewhat loose on bolts and it fires up and idles now.......but there is a gap
Also should the linkage move when pump is out or motor has to be running
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
