TC33D Glow Plug Timer
/ TC33D Glow Plug Timer #31
I have a TC35DA and hve determined that the glow plug timer is faulty. My research found testing info that the timer can be temporarily and quickly bypassed with the harness connector removed by jumping the brown to the black wire in the harness with the ignition switch on. Bypassing too long can burn up the glow plugs but I confirmed this to be a good system check. My question involves trying a Kubota part to replace this pricey timer. Prices on NGK timer S81NF are between $71 and $89.E bay parts search has a kubota NGK S81NL 12 volt timer for about $12! Tempted to try it as it has the same case and pin configuration. Has anyone else tried this? Could someone let me know how long their glow plugs stay lit with timer S81NF? (current New Holland Part #SBA385870301) Thanks, Randy
/ TC33D Glow Plug Timer #33
I have an issue with my TC33 2003. Cold starting takes a lot of cranking.. the glow plug indicator timer seems to work.. but i suspect the glow plugs are not working. What should I do?
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
4004SFL (A59228)
4004SFL (A59228)
2005 Honda Accord LX Sedan (A59231)
2005 Honda Accord...
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
