2003 TC30 Won't Start
/ 2003 TC30 Won't Start #21
The timer relay is only activated by the seat switch. If you hit a bump and your rump leaves the seat, it buys you a moment to get back onto the seat switch before killing the engine. With the seat switch bypassed, that relay now does nothing...unless the seat switch bypass has failed.
Thanks for this reply...... I did find the Timer Relay fits New Holland T2310 T2320 TC25 TC29 TC30 TC33 TC33D TC35 TC40 TZ24DA 1530 SBA385870301 fits Ford SBA385870301 fits Case IH SBA385870301 ..... I have an inquiry in to see if it can be used as a replacement. Pin configuration is different. Will keep posted. I am determined to not get jammed by NH. If need be I will attempt to bypass all of these
Have to say I am pretty pissed with NH.....
Look at these two links and examine the pictures and the pricing!
New Holland Control Unit Part # SBA385870640
The previous timer ending in 40 is listed yet out of stock for $70. When you look up the 41 version, the very same 40 picture comes up with a price tag of $230!!!!
What gives? Feeling like we are getting jammed. Change a number and triple the price!
I would really be pissed if I ordered this part and it was 40 version printed on it with the 41 price tag.
Cheers
/ 2003 TC30 Won't Start #23
Welcome to the world of aftermarket pricing, its not unique to New Holland.
Thankfully here on TBN there are some very knowledgeable people who are willing to help each other out to find ways around these crazy aftermarket prices.
/ 2003 TC30 Won't Start #24
Just bypass it..but keep the clutch switch so you cant start unless its pushed in.
/ 2003 TC30 Won't Start #25
If you're complaining about that you better get rid of that tractor. It only gets worse the more expensive parts you need to by. A rear remote for that tractor runs about 2K. I've read posts in here where people were complaining about paying $400.I would pay that in a heartbeat. I don't know of any brand of vintage CUT that has cheap parts that are still available. Most tractors that age you search for parts, and it comes up obsolete.
I hate it as much as anyone else, but I accept it and relish in the fact that I can do the work myself and that the parts are still available. Most of all the best thing is that all the equipment I own I don't have I any payments on.🍻
Would love to bypass, but easier said than done. Can't find any instructions on that. My tractor doesn't have a clutch switch. Cheers,
SBA385870641 appears to be a timer relay in the seat switch circuit. I am not familiar with that seat circuit as my 1520 does not have it, and my T1520 has the seat circuit (which I have bypassed) built into the safety controller. If your TC30 has the SBA385870641, I assume it does not have a safety controller, and the seat switch circuit consists of the SBA385870641 timer and a relay which shuts of the fuel solenoid. I have 2 thoughts about the timer and its high cost, First, you said you have the seat switch jumpered and in that case, rather than spending $$ on the timer, I would figure out how to get along without it (and maybe the shut off relay). Second, the timer looks to be similar to the glow plug lamp timer, and those NGK oe timers are available for around $20 on amazon. If you want to replace the timer, you might (at your own risk) first try borrowing your glow plug lamp timer and try it in place of the seat timer to see if one of the $20 amazon timers might work. I found no information from the seat timer other than it is an NGK timer of some sort and it looks visually similar to the glow plug lamp timer. All the above is a guess from what I see on a TC30 wiring diagram I found online. The diagram lacks enough detail to tell for certain how the seat circuit works. A service manual is needed to get more information to learn much more.
Thank you for this. Yep saw those glow plug timers. Couldn't find any evidence that it is a replacement so have not attempted to swap. My seat timer is quite different. I might just bite the bullet. Haven't found any instructions on how to bypass and figuring it out is above my pay grade....lol. Thank you again for you input. Will let you know how I make out when I finally complete a fix. Cheers
The thing that irks me is that the discontinued and new parts are identical with the exception of the last digit. Plus I can order a starter for this thing for the same price as this cheap little component.
/ 2003 TC30 Won't Start #29
Seems like a shame to spend that much for a timer when you had the seat switch jumpered anyway. I would need to see detail of the seat switch circuit in the TC30 service manual to know more. I did find this youtube video by someone who may of had the same problem
his explanation is not very clear, but maybe you can pick something up from there.
fwiw, the timer he points out under the hood is the glow plug timer and the relay next to it that he points out, I believe may be the safety relay.
There is another video there by another person with the problem on another TC30, but it is a newer one that has the safety controller. Be happy you do not have that.
Good Luck
Good Luck
Thank for this. Going to give it a try. Was just about to bite the bullet and buy the part. Keep you posted. Cheers,
/ 2003 TC30 Won't Start #31
Correction to what I said above, the timer that he points to under the hood is for the Glow Plug Indicator Lamp and not the glow plugs, For the other TC tractors, I believe it controls both the indicator lamp and a relay that energizes the glow plugs. I suspect the TC30 is similar to the xx20 series where the glow plugs are engerized direct from the ignition key 'heat' position and timer only controls the glow plug indicator light
Good Luck
Well folks!!!! IT WORKED.
Thanks to all that took the time to respond especially toot77.
I was concerned I would blow something up given the difference in years between my tc30 (2003) and this one and the different wire color codes, but the pin out must have been the same and it worked!
F New Holland and their price gouging ways.
Thanks and cheers.
/ 2003 TC30 Won't Start #33
If you used a Scotchlok like the video showed, those things invite corrosion. Fill that thing with anti-oxidant compound, found at most hardware stores in the electrical isle. Do not use dielectric grease, as it absorbs water. Then, wrap it in high quality electrical tape, like 3m super 88. Good job on your fix!
Roger that.... thanks and cheers,
UNUSED SDLANCH HIGH END 5M RATCHET STRAP SET (A64280)
UNUSED SDLANCH...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
JOHN DEERE 9360R ARTICULATING TRACTOR (A64280)
JOHN DEERE 9360R...
(10) NEW SLIDING SCREEN DOOR (A64281)
(10) NEW SLIDING...
10' DISC HARROW (A64276)
10' DISC HARROW...
2017 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A61573)
2017 Eager Beaver...
