TC33D Glow Plug Timer
/ TC33D Glow Plug Timer #31
I have a TC35DA and hve determined that the glow plug timer is faulty. My research found testing info that the timer can be temporarily and quickly bypassed with the harness connector removed by jumping the brown to the black wire in the harness with the ignition switch on. Bypassing too long can burn up the glow plugs but I confirmed this to be a good system check. My question involves trying a Kubota part to replace this pricey timer. Prices on NGK timer S81NF are between $71 and $89.E bay parts search has a kubota NGK S81NL 12 volt timer for about $12! Tempted to try it as it has the same case and pin configuration. Has anyone else tried this? Could someone let me know how long their glow plugs stay lit with timer S81NF? (current New Holland Part #SBA385870301) Thanks, Randy
/ TC33D Glow Plug Timer #33
I have an issue with my TC33 2003. Cold starting takes a lot of cranking.. the glow plug indicator timer seems to work.. but i suspect the glow plugs are not working. What should I do?
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
2020 DRAGON ESP...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2014 International Maxxforce DT (A53317)
2014 International...
2017 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2017 Ram 2500 4x4...
