TC33 and 6ft rotary?
   / TC33 and 6ft rotary? #1
mathey
Platinum Member
MD
NH TC33D
i couldn't find on the NH website which implements are rated for which tractors...
will a tc33 hst pull a 6' rotary mower?
THX
THX
   / TC33 and 6ft rotary? #3
Try checking out LandPride's website; locate rotary cutters. They provide the recommended horsepower for the rotary cutter.
TC33 and 6 ft cutter may be okay; but it depends on what you're cutting. You get into heavy weeds, hay or whatnot and it will bog down the engine.
Just my experience on a TN65 and I have a 6 ft cutter.
   / TC33 and 6ft rotary? #4
well, the Bush Hog web site said
Recomm. Tractor HP 60" 25 to 40
72" 30 to 45
the TC33 is 33 gross HP and 27 PTO hp...
so I'd say a 72 was marginal at best?
My ground is flat, mostly pasture, and never very tall...Seems like a 6' finish mower wouldn't be as taxing on the TC33.
72" 30 to 45
   / TC33 and 6ft rotary? #7
mathey:
According to printed NH literature the TC33 will pull a 951B 72" Rotary Cutter. I agree with all previous posts as to actual use and power requirements. I would look at what you really have to cut in order to make your actual decision. Good luck on your research and purchase. Jay
   / TC33 and 6ft rotary? #8
mathey:
   / TC33 and 6ft rotary? #9
That has roughly the same HP as a 1953/1954 ford NAA.. and it was rated for a 6' cutter.. if you get into heavy stuff.. just take a 5' bite.
The guy with the 65 hp tractor and 6' mower can probably cut stands of 2.5" stuff with that much extra hp..
Soundguy
   / TC33 and 6ft rotary? #10
Soundguy
UNUSED FUTURE BC72 - 72" HYD BLOCK CRUSHER (A51248)
UNUSED FUTURE BC72...
SCAN FOR HAULING AND FINANCING INFORMATION (A51247)
SCAN FOR HAULING...
2004 Kia Optima Sedan (A51694)
2004 Kia Optima...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
PALLET OF NEW HOLLAND PARTS (A51248)
PALLET OF NEW...
UNUSED PAIR OF FUTURE 7" RUBBER TRACKS (A51248)
UNUSED PAIR OF...
