TC33 and 6ft rotary?
   / TC33 and 6ft rotary? #1
mathey
Platinum Member
MD
NH TC33D
i couldn't find on the NH website which implements are rated for which tractors...
will a tc33 hst pull a 6' rotary mower?
THX
THX
   / TC33 and 6ft rotary? #3
Try checking out LandPride's website; locate rotary cutters. They provide the recommended horsepower for the rotary cutter.
TC33 and 6 ft cutter may be okay; but it depends on what you're cutting. You get into heavy weeds, hay or whatnot and it will bog down the engine.
Just my experience on a TN65 and I have a 6 ft cutter.
   / TC33 and 6ft rotary? #4
well, the Bush Hog web site said
Recomm. Tractor HP 60" 25 to 40
72" 30 to 45
the TC33 is 33 gross HP and 27 PTO hp...
so I'd say a 72 was marginal at best?
My ground is flat, mostly pasture, and never very tall...Seems like a 6' finish mower wouldn't be as taxing on the TC33.
72" 30 to 45
   / TC33 and 6ft rotary? #7
mathey:
According to printed NH literature the TC33 will pull a 951B 72" Rotary Cutter. I agree with all previous posts as to actual use and power requirements. I would look at what you really have to cut in order to make your actual decision. Good luck on your research and purchase. Jay
   / TC33 and 6ft rotary? #8
mathey:
   / TC33 and 6ft rotary? #9
That has roughly the same HP as a 1953/1954 ford NAA.. and it was rated for a 6' cutter.. if you get into heavy stuff.. just take a 5' bite.
The guy with the 65 hp tractor and 6' mower can probably cut stands of 2.5" stuff with that much extra hp..
Soundguy
   / TC33 and 6ft rotary? #10
Soundguy
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
HANG ON MAST W/ 58" FORKS (A51247)
HANG ON MAST W/...
(APPROX 50) 2" X 2" X 98" TUBING (A51247)
(APPROX 50) 2" X...
UNUSED AGT QUICK ATTACH AUGER SET (A51248)
UNUSED AGT QUICK...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
