TC29D losing power
   / TC29D losing power #1
FHTM_JK
Lexington, TN
2001 NH TC29D; 1951 Ford 8N
2001 TC29D...While mowing, it began to bog down...pushed in clutch...waited about a minute while it stumbled and stuttered, then it was fine again for about 5 minutes...keeps doing this...grass is not unusually high...fuel tank is about 1/2 full...mowing with a Woods RD7200 rear-mounted finishing mower.
I'm the second owner of this tractor and have only put around 100 hours on it since I bought it last summer. All I've done to this point is clean the chaff off the radiator screen. After I saw your question, I checked the air filter (OK) and fuel filter...oops! Not so clean...replace it with a new one and the tractor runs like new! Amazing how that works...
Thank you guys for your quick responses.
JK
When is the last time you changed your fuel filter(s)?
   / TC29D losing power #5
Run some diesel fuel conditioner and maybe algaecide in the tank. You can also remove the fuel line to the fuel filter bowl inlet and see that it has a 'full' flow---if not, blow hard on the line and then see if it cleared some contaminates and flows freely. This lack of full fuel flow is common and causes problems.
Sam:)
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
Stehl Tow Dolly (A50514)
Stehl Tow Dolly...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
2007 Jeep Liberty (A50515)
2007 Jeep Liberty...
2013 POLARIS RANGER 800 EFI UTV (A51243)
2013 POLARIS...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
