TC29D losing power
   / TC29D losing power #1
FHTM_JK
Member
Lexington, TN
2001 NH TC29D; 1951 Ford 8N
2001 TC29D...While mowing, it began to bog down...pushed in clutch...waited about a minute while it stumbled and stuttered, then it was fine again for about 5 minutes...keeps doing this...grass is not unusually high...fuel tank is about 1/2 full...mowing with a Woods RD7200 rear-mounted finishing mower.
I'm the second owner of this tractor and have only put around 100 hours on it since I bought it last summer. All I've done to this point is clean the chaff off the radiator screen. After I saw your question, I checked the air filter (OK) and fuel filter...oops! Not so clean...replace it with a new one and the tractor runs like new! Amazing how that works...
Thank you guys for your quick responses.
JK
When is the last time you changed your fuel filter(s)?
   / TC29D losing power #5
Run some diesel fuel conditioner and maybe algaecide in the tank. You can also remove the fuel line to the fuel filter bowl inlet and see that it has a 'full' flow---if not, blow hard on the line and then see if it cleared some contaminates and flows freely. This lack of full fuel flow is common and causes problems.
Sam:)
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
2019 Kenworth T680 Tandem Axle Road Tractor (A47384)
2019 Kenworth T680...
CASE 1150C CRAWLER DOZER (A51242)
CASE 1150C CRAWLER...
2024 JT10 - 5' X 10' TRAILER (A51243)
2024 JT10 - 5' X...
Bush Hog (A50322)
Bush Hog (A50322)
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
