TC29D losing power
   / TC29D losing power #1
FHTM_JK
Lexington, TN
2001 NH TC29D; 1951 Ford 8N
2001 TC29D...While mowing, it began to bog down...pushed in clutch...waited about a minute while it stumbled and stuttered, then it was fine again for about 5 minutes...keeps doing this...grass is not unusually high...fuel tank is about 1/2 full...mowing with a Woods RD7200 rear-mounted finishing mower.
I'm the second owner of this tractor and have only put around 100 hours on it since I bought it last summer. All I've done to this point is clean the chaff off the radiator screen. After I saw your question, I checked the air filter (OK) and fuel filter...oops! Not so clean...replace it with a new one and the tractor runs like new! Amazing how that works...
Thank you guys for your quick responses.
JK
When is the last time you changed your fuel filter(s)?
   / TC29D losing power #5
Run some diesel fuel conditioner and maybe algaecide in the tank. You can also remove the fuel line to the fuel filter bowl inlet and see that it has a 'full' flow---if not, blow hard on the line and then see if it cleared some contaminates and flows freely. This lack of full fuel flow is common and causes problems.
Sam:)
IH 686 Tractor (A50514)
IH 686 Tractor...
2000 Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2000 Lull...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
2022 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
2022 CATERPILLAR...
