TC29D Hst Pedals Sticking
   / TC29D Hst Pedals Sticking #1
Carl G
Spoiled785!1
1999 29D and the hst pedal sticks in fwd and reverse. I took the spring out and it seems fine. Greased everything and adjusted, but the pedal still stays whichever way it’s pushed. I also unhooked the wiring to the cruise since it wanted to stay engaged once pushed. Am I missing another adjustment point? Do I need to replace something?
   / TC29D Hst Pedals Sticking #2
One of the things I did concerning the cruise control sticking was to glue 3 or 4 short strips of a nylon zip tie to the surface of the cruise magnet. It still holds when energized but releases cleanly when shut off.
   / TC29D Hst Pedals Sticking #3
Did you lube the shaft that the cruise paddle rides on? There is also a damper (sba378910020) that slows the pedal movement. Then there is the peddle centering device that has a spring, rod, and guides inside and it is suppose to get the pedal to neutral when released.
Did you lube the shaft that the cruise paddle rides on? There is also a damper (sba378910020) that slows the peddle movement. Then there is the peddle centering device that has a spring, rod, and guides inside and it is suppose to get the peddle to neutral when released.
I adjusted and greased this spring. The further down I went with the nut, the more the forward pedal would come back to center. But reverse wouldn’t and there was less travel for reverse.
I think this is the centering device?
Where would I find the damper?
The cruise is completely unhooked. I had to use a screwdriver to release the magnet from the pedal. Something is wrong with the return for that.
   / TC29D Hst Pedals Sticking #9
Further thought on the issue, and I recall the cruise control plate was rubbing on the fuel tank. I had to remove it and grind it down to provide more clearance.
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
2019 FREIGHTLINER SPRINTER 2500 (A51219)
2019 FREIGHTLINER...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2018 BOBCAT T450 SKID STEER (A51242)
2018 BOBCAT T450...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
