TC29D Hst Pedals Sticking
   / TC29D Hst Pedals Sticking #1
Carl G
Spoiled785!1
1999 29D and the hst pedal sticks in fwd and reverse. I took the spring out and it seems fine. Greased everything and adjusted, but the pedal still stays whichever way it’s pushed. I also unhooked the wiring to the cruise since it wanted to stay engaged once pushed. Am I missing another adjustment point? Do I need to replace something?
   / TC29D Hst Pedals Sticking #2
One of the things I did concerning the cruise control sticking was to glue 3 or 4 short strips of a nylon zip tie to the surface of the cruise magnet. It still holds when energized but releases cleanly when shut off.
   / TC29D Hst Pedals Sticking #3
Did you lube the shaft that the cruise paddle rides on? There is also a damper (sba378910020) that slows the pedal movement. Then there is the peddle centering device that has a spring, rod, and guides inside and it is suppose to get the pedal to neutral when released.
Did you lube the shaft that the cruise paddle rides on? There is also a damper (sba378910020) that slows the peddle movement. Then there is the peddle centering device that has a spring, rod, and guides inside and it is suppose to get the peddle to neutral when released.
I adjusted and greased this spring. The further down I went with the nut, the more the forward pedal would come back to center. But reverse wouldn’t and there was less travel for reverse.
I think this is the centering device?
Where would I find the damper?
The cruise is completely unhooked. I had to use a screwdriver to release the magnet from the pedal. Something is wrong with the return for that.
   / TC29D Hst Pedals Sticking #9
Further thought on the issue, and I recall the cruise control plate was rubbing on the fuel tank. I had to remove it and grind it down to provide more clearance.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
3410 (A47477)
3410 (A47477)
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
19010 (A55851)
19010 (A55851)
John Deere 6120M (A57148)
John Deere 6120M...
