TC 35 won't turn over.
   / TC 35 won't turn over.
Thanks Jim. Will get out there in a few minutes and check that out. Will keep you posted!
   / TC 35 won't turn over. #12
Just a quick note. My 2005 TC35A does have a brake and a PTO light on the dash.
Christopher
   / TC 35 won't turn over. #13
Christopher
I checked the early instrument panels on the TC35 (prior to 2004) and my diagrams and schematics all showed no lights for the parking brake and PTO as Jeff mentioned. I think yours were added on that later model tractor.:)
   / TC 35 won't turn over. #14
Jeff, earlier you mentioned cutting the wires off the seat switch and jumpering them together. I have a different solution. Disconnect the seat switch as shown in the photo below and jumper using two spade connectors on the ends of a wire. Then set the wire out of the way. If you ever want to hook it back up, just pull the jumper and plug it in. That's a whole better way of doing the seat jumper than cutting the wires since cutting is a permanent thing.
Thanks for all your help Jim. The #2 fuse was blown. A simple 7.5 fuse has shut me down for about 4 days. So glad I didn't have the dealer come pick the tractor up. Mowed all day and can now get the garden out! Appreciate the pics on the safety switch. That's a better idea!
   / TC 35 won't turn over. #16
Once again Jim has helped someone get their tractor going as others have also done on this forum in the past, it's a great resource for anyone who has a tractor.
   / TC 35 won't turn over. #17
Awesome! I'm glad I could help.:thumbsup: What I and others have done is to replace that fuse with a self-resetting circuit breaker. I would suggest a 10-amp CB instead of the 8-amp. NAPA's part number is: NAPA part # BK 7823120 , $6.49 each, but several other auto parts stores carry them now. It can save you from being stuck if the fuse blows and you don't have a replacement. The CBs are the same size as a fuse and have legs you can break off so their length will fit exactly as the fuse would.
They look like this below:
   / TC 35 won't turn over. #18
Jim--Can you share any knowledge on why the #2 fuse seems to have a history beit notorious with the TC series?
   / TC 35 won't turn over. #20
Thanks jinman, your thread is right on the money. Just had the problem. Appreciate.
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
1999 NUTTALL FOUR AXLE TRAILER (A58214)
1999 NUTTALL FOUR...
Eagle Weathervane (A55853)
Eagle Weathervane...
