TC 35 won't turn over.
   / TC 35 won't turn over.
Thanks Jim. Will get out there in a few minutes and check that out. Will keep you posted!
   / TC 35 won't turn over. #12
Just a quick note. My 2005 TC35A does have a brake and a PTO light on the dash.
Christopher
   / TC 35 won't turn over. #13
Christopher
I checked the early instrument panels on the TC35 (prior to 2004) and my diagrams and schematics all showed no lights for the parking brake and PTO as Jeff mentioned. I think yours were added on that later model tractor.:)
   / TC 35 won't turn over. #14
Jeff, earlier you mentioned cutting the wires off the seat switch and jumpering them together. I have a different solution. Disconnect the seat switch as shown in the photo below and jumper using two spade connectors on the ends of a wire. Then set the wire out of the way. If you ever want to hook it back up, just pull the jumper and plug it in. That's a whole better way of doing the seat jumper than cutting the wires since cutting is a permanent thing.
Thanks for all your help Jim. The #2 fuse was blown. A simple 7.5 fuse has shut me down for about 4 days. So glad I didn't have the dealer come pick the tractor up. Mowed all day and can now get the garden out! Appreciate the pics on the safety switch. That's a better idea!
   / TC 35 won't turn over. #16
Once again Jim has helped someone get their tractor going as others have also done on this forum in the past, it's a great resource for anyone who has a tractor.
   / TC 35 won't turn over. #17
Awesome! I'm glad I could help.:thumbsup: What I and others have done is to replace that fuse with a self-resetting circuit breaker. I would suggest a 10-amp CB instead of the 8-amp. NAPA's part number is: NAPA part # BK 7823120 , $6.49 each, but several other auto parts stores carry them now. It can save you from being stuck if the fuse blows and you don't have a replacement. The CBs are the same size as a fuse and have legs you can break off so their length will fit exactly as the fuse would.
They look like this below:
   / TC 35 won't turn over. #18
Jim--Can you share any knowledge on why the #2 fuse seems to have a history beit notorious with the TC series?
   / TC 35 won't turn over. #20
Thanks jinman, your thread is right on the money. Just had the problem. Appreciate.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
13 Ft Ball hitch Trailer (A56859)
13 Ft Ball hitch...
LOT: (2) Cargo Van Shelving Units, (2) Steel Shelves (A59076)
LOT: (2) Cargo Van...
48in Forklift Safety Basket (A56857)
48in Forklift...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
Black Metal Roof Panels (A55758)
Black Metal Roof...
