TC 33D hydro problem alert
   / TC 33D hydro problem alert #11
No, the engine was not running. I checked them to see if they have ever leaked. There was no sign that they have ever leaked. I will watch them often when I start using my tractor again.
Sherpa
   / TC 33D hydro problem alert #12
You have to check them when the tractor is running so the hoses are under pressure. That's when it's easiest to see if they are starting to crack. Mine looked fine when the engine was off.
   / TC 33D hydro problem alert #13
OK, I see what you are saying now. I will get it hot and take a look again. I would think that you could buy better hose from an auto parts supply house somewhere?
sherpa
   / TC 33D hydro problem alert #14
The problem is that these hoses are high pressure hydraulic hoses. It would be easy enough to replace if the hose was straight, but the 90 degree turn will kink hydraulic hose.
The best suggestion I've seen is to put a series of nylon cable ties around the hose, preventing expansion.
   / TC 33D hydro problem alert #15
How about wrapping the hose with fiber-reinforced packaging tape. The tape is narrow enough to wrap the right-angle hoses without to much creasing of the tape and that stuff is virtually unbreakeable. The 3/4" wide version should work very well.
   / TC 33D hydro problem alert #16
There is a place that I buy my hydraulic hoses from, he custom makes each hose with ends while I wait, I bet he has something.
sherpa
   / TC 33D hydro problem alert #17
<font color="blue"> I bet he has something. </font>
If he does, let us know. /forums/images/graemlins/laugh.gif
   / TC 33D hydro problem alert #18
</font><font color="blue" class="small">( straight, but the 90 degree turn will kink hydraulic hose.
)</font>
This isn't a hydro.. or a boomer.. but I just looked under the front nose-hood of my NH 7610s, and it has an oil cooler as well. Instead of right angle bends, the dealer installed longer hoses, and makes a coil if you will.. so the right angle turn is made up with a 'loop' of hose. Seems to be working good. Hose looks to be pretty stiff.. at least 2 wire.
Soundguy
   / TC 33D hydro problem alert #19
<font color="blue"> Instead of right angle bends, the dealer installed longer hoses, and makes a coil if you will.. so the right angle turn is made up with a 'loop' of hose. </font>
I think murph (thcri) did this until he could get the 90 degree hoses from his NH dealer. Perhaps this is a better solution.
2018 Peterbilt 567 T/A Day Cab Truck Tractor (A60460)
2018 Peterbilt 567...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2003 Freightliner FLD 120 Columbia (A56436)
2003 Freightliner...
