TC 33 D PTO Light
/ TC 33 D PTO Light #1
marty
Mid West
Boomer 33D
Has anyone noticed their tractors rear-PTO light staying halfway lit while the PTO is not engaged. I noticed this a while back and then it went away and now it has come back.
/ TC 33 D PTO Light #2
I haven't seen anything like that. About 130 hrs now. My wife did inform me this weekend that the cruise control doesn't work - I'll have to get that looked into when I'm not using it.
/ TC 33 D PTO Light #3
If I can stop in here for a moment as a non owner. (not yet) Hope what you are seeing is a loose wiring harness or connection. The amount of reostats and pots on the new ones still eludes me. Something I'll have to look closer at. Hope these are easy fixes and both of you report back.
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
/ TC 33 D PTO Light #4
I have aTC29D which had the same problem. I found a loose connection in the wiring harness directly below the PTO levers (plug-in is located a few inches above the axle) the connection was half out of its socket. A piece of brush was still hanging on the plug-in.
/ TC 33 D PTO Light
I could never find a loose wire and when I had the tractor in the dealer installed a new sensor unit; however the light still stays on half way - any ideas.
/ TC 33 D PTO Light #6
I would check for foreign material in both of the PTO switches ( dirt or water or a combination of both). has the tractor been near water or been sprayed with water?
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
