TC 33 D PTO Light
/ TC 33 D PTO Light #1
marty
Mid West
Boomer 33D
Has anyone noticed their tractors rear-PTO light staying halfway lit while the PTO is not engaged. I noticed this a while back and then it went away and now it has come back.
/ TC 33 D PTO Light #2
I haven't seen anything like that. About 130 hrs now. My wife did inform me this weekend that the cruise control doesn't work - I'll have to get that looked into when I'm not using it.
/ TC 33 D PTO Light #3
If I can stop in here for a moment as a non owner. (not yet) Hope what you are seeing is a loose wiring harness or connection. The amount of reostats and pots on the new ones still eludes me. Something I'll have to look closer at. Hope these are easy fixes and both of you report back.
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
/ TC 33 D PTO Light #4
I have aTC29D which had the same problem. I found a loose connection in the wiring harness directly below the PTO levers (plug-in is located a few inches above the axle) the connection was half out of its socket. A piece of brush was still hanging on the plug-in.
/ TC 33 D PTO Light
I could never find a loose wire and when I had the tractor in the dealer installed a new sensor unit; however the light still stays on half way - any ideas.
/ TC 33 D PTO Light #6
I would check for foreign material in both of the PTO switches ( dirt or water or a combination of both). has the tractor been near water or been sprayed with water?
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-350...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2023 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2023 Chevrolet...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
