TC-29 DA Hydraulic problem
   / TC-29 DA Hydraulic problem #1
V1Rotate
Platinum Member
New Holland TC 29D
Hey guys
Today when I went to use the loader it was acting very strange.
The raise/lower function seems to work ok but curl function is messed up.
If I pull the joystick to the left, the bucket seems to curl back normally but when I move the joystick to the right about half way, the bucket will curl forward but there is a screeching sound, like the bypass valve is opening, and there is very litle force pushing the bucket. Also, if I move the joystick all the way to the right, the bucket will curl back rapidly.
If I put the bucket on the ground and try to curl the bucket forward to raise the front wheels off the ground, nothing happens.
I removed the plastic cover that surrounds the loader control valve and nothing looks out of the ordinary on the exterior of the valve.
Any ideas?
Thanks
   / TC-29 DA Hydraulic problem #2
Check all the disconnect hydraulic fittings: remove and reseat.
Jim
Jim
I just did that and found one of the QDs was loose. Reconnected it and all is good now.
Thanks
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
