TC-29 DA Hydraulic problem
   / TC-29 DA Hydraulic problem #1
V1Rotate
New Holland TC 29D
Hey guys
Today when I went to use the loader it was acting very strange.
The raise/lower function seems to work ok but curl function is messed up.
If I pull the joystick to the left, the bucket seems to curl back normally but when I move the joystick to the right about half way, the bucket will curl forward but there is a screeching sound, like the bypass valve is opening, and there is very litle force pushing the bucket. Also, if I move the joystick all the way to the right, the bucket will curl back rapidly.
If I put the bucket on the ground and try to curl the bucket forward to raise the front wheels off the ground, nothing happens.
I removed the plastic cover that surrounds the loader control valve and nothing looks out of the ordinary on the exterior of the valve.
Any ideas?
Thanks
   / TC-29 DA Hydraulic problem #2
Check all the disconnect hydraulic fittings: remove and reseat.
Jim
Jim
I just did that and found one of the QDs was loose. Reconnected it and all is good now.
Thanks
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A56858)
2008 Ford E-350...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
2010 Toro Workman MD Utility Cart (A55973)
2010 Toro Workman...
