task master TM 432
/ task master TM 432 #1
bill72562
Hi - I have a Taskmaster TM432 for sale. It is a 32HP tractor with loader.
I bought this tractor new from the importer in Creswell Oregon. I have had this tractor for about 5 years. I have had numerous problems with the tractor over the years, generally i have been able to repair it. Generally my repair is much better than new.
Right now the rear differential housing is cracked. A new housing is available from the dealer in Creswell for about $350. Unfortunately they want $3000 to install it. Somebody who has time and the ability to deal with heavy gear cases should be able to get this tractor running again.
/ task master TM 432 #2
Any idea what caused it to break? I've not worked on one of these, but generally speaking, it isn't difficult to work on the rear axle housings.
/ task master TM 432 #3
I have housings in stock and can install it if you just want to get it fixed.
Buck
I can't find any reason for the housing to crack. Don't see impacts or dents. The tractor still drives, so the differential seems ok. I suspect it is just chinese castings. There seems to be no specific reason for things breaking on these tractors.
How much money and how much time?
I think the tractor has to be split at the clutch.
