Tandem Disc: Make & Model?
   / Tandem Disc: Make & Model? #1
sresites
Bronze Member
Tracy, CA
1997 Case 5250
Cannot identify this disc. Anyone have an idea? Thanks.
   / Tandem Disc: Make & Model? #2
Technically the disk in your photo isn't referred to as a tandem disk but by offset disk. Sorry I don't recognize the brand of that offset disk. Due to the amount of wear on the disks IE absence of cut-outs it appears to be very experienced at moving soil.
   / Tandem Disc: Make & Model? #3
Not sure, but looks like a good one.
Is there a clearer image where you can actually read whats on the side? Looks like Cop___
Yah, oops on using the term tandem. I’ve been looking for a tandem so much but was impressed with this offset that popped up.
No other clearer pic found. I’ll try Google pic search when I get to the office today.
Shoot. Right in my backyard. Thank you
   / Tandem Disc: Make & Model? #7
Offset disc. Takes a lot more tractor for that one. Our big tractor weighs 15,000# and an 8' offset is all it wants. If it was 8' 1", probably wouldn't pull it.
   / Tandem Disc: Make & Model? #8
I have an 8' tandem but very, very heavy disc and it's all my tractor wants.
   / Tandem Disc: Make & Model? #9
I couldn't imagine an 8' offset being all a 15,000 pound tractor wants. What size are the disc pans? I pull a 9' offset disc with 26" pans that weighs 3k give or take a few pounds with a 93 hp JD 4x4 tractor that with loaded tires and FEL probably only weighs in at 10k.
   / Tandem Disc: Make & Model? #10
Ours is an International pull type with hydraulic wheels to lift it. Maybe your dirt is different. I do know that offset discs will tear the world up. Lot of times we just break the garden with it because it cuts so good. Then we have a large butane tank we made a packer out of, pull that over it and lay the rows out with a Covington planter on a cultivator. We learned to use that packer because if it rains, garden won't be near as boggy.
That same tractor will boil the dirt over the back of a 5 yd dirt pan, Me, dad, brother, all done that before.
