Tandem Disc: Make & Model?
   / Tandem Disc: Make & Model?
I regretted selling my Strathmore 8’ tandem way back when after selling my Kubota L35. That L35 could pull that Strathmore with ease. To replace that disc will be 4 times the money now for new. Absolutely a great disc.
   / Tandem Disc: Make & Model? #12
In regards to the end result, an offset bears little resemblance to a tandem.
I consider an offset to be a plow.
I consider a tandem to be a finish tool.
That's a heavy duty offset. I agree with Jim. It's got some serious hours on it.
This is my larger tractor and Kewanee 1100 17’ tandem flat fold.
Heading up to Portland OR today to pick up a Kverneland MZ-9 2btm 16” plow.
   / Tandem Disc: Make & Model? #15
I like that turn plow. I wish I could find a three or four plow like that.
Here’s my JD 1600 plow set up for 18” furrow. Can be adjusted for 14 & 16 as well. Spent a lot of time rebuilding it. My Case 5250 glides right along with it in hard pasture ground.
   / Tandem Disc: Make & Model? #17
Here’s my JD 1600 plow set up for 18” furrow. Can be adjusted for 14 & 16 as well. Spent a lot of time rebuilding it. My Case 5250 glides right along with it in hard pasture ground. View attachment 784470
You see a lot of old turn plows at auctions these days except most of them don't have the leading or cutting coulters like yours, they make a difference when flipping sod.
Just picked up the Kverneland plow a couple hours ago. Took it to the Carwash. That plow cleaned up very nicely.
   / Tandem Disc: Make & Model? #19
Unique plow for sure!!!
This was my previous KV before I was upsizing. It was (?) the model MB3BN that you couldn’t replace the number 3 bottoms with OEM. this plow did work the L35 pretty good but no worse than my Case 2-16 or Oliver 2-18.
Mohawk TP-15 15,000lb Two Post Auto Lift (A55852)
Mohawk TP-15...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2016 Jeep Wrangler Unlimited SUV (A55853)
2016 Jeep Wrangler...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
