tackometer quit working
   / tackometer quit working #1
massey 471
massey ferguson 471
On my 471 Ferguson the tack quit working the hours meter still works.Need a wireing diagram. I didn't see a cable so I am not sure exactly how it is suposed to work. Any Ideas?
   / tackometer quit working #2
iirc, electrical tachometer runs off coil.
Since it is a diesel not sure about a coil I will try to trace wire to the alternater, Thanks
   / tackometer quit working #4
lol!... yup, i guess that pours water on the coil idea.
are you saying you can't tell whether the tach is mechanical or electric?
I know it dosn't have a cable so I am thinking I need a wireing diagram to trace all of the wires comming out of the tack If you know how to get a wireing diagram it would be appreciated the local dealer is not much help, thanks
   / tackometer quit working #6
you might try an engine manual.
if it's a perkins you shouldn't have any trouble finding something.
look for the tachometer sending unit/pickup... probably in the area of a rotating mass... maybe flywheel or crankshaft? could be camshaft too... unless the injection system is electronic it has to pick up the signal from some mechanical source. think of the rotor in a distributor cap... every time it goes by a certain point it sends a signal.
so if you determine the engine and then find out how they deal with the tach issue, you should find the sender.
5' Box Blade (A50123)
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2012 Ford F-450...
2017 Ram 4500 Bucket Truck (A53473)
2017 Ram 4500...
2019 John Deere HPX815E (A50123)
2019 John Deere...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
