tachometer question
/ tachometer question
Is that yours? I went on line and found some $200..-$300. didn't won't to spend that much. Thanks
/ tachometer question #12
Yes and no, we have one at work, that was a similar example. You touch the little round knob on the end into the end of a spinning shaft and it gives RPM. Or you can put a little wheel on it and lay that against a moving surface (like a conveyor belt) and it gives travel rate (ft/min for example)
They are a little spendy, that's why I was wondering if you knew anyone who had access to one.............
/ tachometer question #13
It's just not that critical, 2200-2300rpm should work fine.
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
CAT Chassis Only (A59076)
CAT Chassis Only...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
