Tachometer / Hour meter
/ Tachometer / Hour meter #1
white_ja
Lancaster, KY
Jinma 204
Hey folks. Since I bought my tractor and got it running, my tach / hour meter doesn't work. I have studied the wiring diagram in the manual but can't seem to make sense of it with regards to the tach wiring. I also did a search and didn't find anything useful. I have attached a drawing of the rear of my tach. Can someone confirm if I have the correct color wires on the posts before I go thru the adjustment of the sensor? I'm thinking it is either wired wrong or defective, cause the hour meter doesn't work with the key on. BTW, I have a Jinma 204 with separate gauges.
All the other gauges work except my OPG. It worked and then stopped after an hour or so. Probably due to the many times I had the injection pump apart, lines loose, etc. Doesn't matter anyway, I'm gonna replace it with a mechanical gauge.
/ Tachometer / Hour meter #3
Is the sensor screwed in far enough? Should be screwed in till it touches the flywheel and then backed out 1 complete turn?
Billy
Thanks, John. I saw this drawing on your web-site but it doesn't have the color-code for the wires. I can't see the wire tag numbers on mine. You wouldn't know the colors would you?
Billy, I haven't checked it yet. Didn't get a chance this weekend either. I'm pulling the engine on my son's Navigator. Hopefully, I'll get a chance to work on it this week.
John
/ Tachometer / Hour meter #6
Color coding between tractors is not always consistant. If I have time tonight, will tell you what mine is.
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
2014 FORD F-150 (A67714)
2014 FORD F-150...
Doesnt start. No compression. (A64553)
Doesnt start. No...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
