Tach/Electrical Issue
/ Tach/Electrical Issue #61
I have the same problem you're having, mine started slow at first, the neutral light was the first thing I remembered not lighting up, now I'm in the same boat you're in. Hope you get your machine fixed, Mine is still not working,
/ Tach/Electrical Issue #62
I checked my fuses and I only have .3 volts on the bottom 3 fuses, I think they are the lights, inst. panel and panel lights, Got to do a little more digging to see why no voltage to these fuses.
/ Tach/Electrical Issue #63
So did anyone ever get their tractors fixed?
got mine fixed today, it was the relay under the hood, the blue one on the far right hand side, I would like to thank everyone that has commented on this and without all your help I was about to take it in to the dealer and would has cost me an arm & leg. Thanks again for all the good suggestions. Steve
/ Tach/Electrical Issue #65
I'm having an similar issue with my 2011 ct235. No headlights and the tach/dash worked intermittently and finally quit. Does anyone have wiring diagram? The dealer gave me a parts breakdown that shows all the relays but none of look like they relate to the dash. Thanks.
I'm having a very similar problem on 2013 CT235 Could someone point me in the right direction and which relay I should be looking and replacing? Anyway to determine it is the relay by troubleshooting? I have checked the battery and ground connections and this hasn't helped. Thanks in advance!
/ Tach/Electrical Issue #66
Me too. 2011 (I think) CT235 with 415 hours. A couple times this month I'd go start and no solenoid click. But subsequently key off and on and it would click. Yesterday, I lost power to my rear accessories circuit. Then a few hours later I lost headlights and gauges. Have signal lights, horn, turn signals. Looked for shorts underneath and under the hood... Nothing. Will be checking this far right side (facing the firewall from the front) relay in the engine compartment and hope this will prove the culprit. Will update tomorrow.
/ Tach/Electrical Issue #67
Anyone know where the switched power relay is on the CT235? On the fire wall from right to left when facing from the front, the fuel sender is beside the OCU. Then the fuel pull relay, the starter relay, and the pre-heat relay. No switched relay as is according to the CT335 right beside the fuel sender.
/ Tach/Electrical Issue #68
I assume this is it? Directly above the Flasher Unit on the left side beneath the instrument panel shroud. IMG_20190626_102951.jpeg
/ Tach/Electrical Issue #69
I assume this is it? Directly above the Flasher Unit on the left side beneath the instrument panel shroud. View attachment 610536
Can not make out wire colors in the photo, 4 wires at the Switched power relay are Black (grd), Red (battery), Red/white strip (switch input), Red/Blk stripe (out to dash & lights).
/ Tach/Electrical Issue #70
Thanks for the insight. It ceased being problematic but I'm sure it's not the last I've heard of it.
43024 (A59228)
43024 (A59228)
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2018 Ford Escape SUV (A59231)
2018 Ford Escape...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
