Ta da! 2 dead moles!
   / Ta da! 2 dead moles! #1
Pilot
Veteran Member
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
I've never had any luck killing moles. 3 Victor Out O'Sight traps, in 24 years, 1 kill, but I admit I wasn't trying all the time. Tried a mound of dirt under the trigger, they just dug around it, under or over it, never thru it. Used a rock under the trigger, no luck. A friend came over with his blaster and a few weeks later the mounds appeared again (maybe new moles, illegal aliens from the neighbors). He also showed me how to gas them by pouring sulfur down the hole and burning it with a weed burner which produced poisonous gas, (don't try this, burning sulfur is listed as very toxic) which had about the same result as the blaster. I tried a "Molecat" a sort of gun that fires .27 caliber blanks used in construction. The dirt the mole was pushing forward and which fired the gun absorbed the blast & I could hear the mole laugh at it. I had just about given up, but I had put in new lawn last year & the the moles invaded in regimental forces.
Then someone told me about Christine. Christine lives half a mile away and someone pointed out that her lawn was like a carpet, zero mole mounds.
Christine came over and gave me a lesson in mole trapping. Showed me how to set the Victor traps, but said they aren't very good--no news to me--and said Trapline traps (Welcome to Trapline Products) are much better. Showed me how to set the Trapline trap and suggested sticking a flag (a plastic flag about 3" X 3" and attached to a wire) thru the loop on the end of the trap to keep a wounded mole from dragging the trap into the tunnel.
Finally went trapping less than a week ago. Set my 2 Victors and my 4 Traplines. Checked the Victors every day or two, but not the Traplines because you can't check them without pulling them partly out of the tunnel, then you have to reset the trap in the tunnel, that you have messed up and that may not work well.
But today, I decided to dig them up and move the traps to a different area, assuming I hadn't caught anything, since I had such bad luck in the past.
Score: Traplines, 2 kills, one probable and one zero. Victors, defeated with a score of zero, as usual. The probable was where I forgot to set the flag and in digging up the hole the trap was gone. Probing the tunnels didn't result in anything, so a wounded mole may have dragged the trap further down the tunnel.
Gonna order more traps & they won't be Victors.
   / Ta da! 2 dead moles! #2
I'll tell it again.
My Dad had problems with moles once in northern Vermont. To me he had an elegant solution. He'd buy a bunch of fireworks. Put on his thick soled hunting boots. Go out, drop a lit firework in a recent hole, step on it. Repeat.
I doubt he ever KILLED a mole, but they moved away.
And any excuse to light explosives is a good thing :)
   / Ta da! 2 dead moles! #3
Ours are back with reinforcements, need to be methodical about it and get it done. Dog likes to dig in the holes right now so will have to figure out keeping her safe..
   / Ta da! 2 dead moles! #4
If you have a lot of grubs in your lawn you need to kill the grubs. The moles are probably there to eat the grubs.
You also might want to try a Macabee trap or two. I think they work for moles as well as gophers.
Macabee is the oldest operating business in Los Gatos, CA (Silicon Valley). A friend of mine is part owner though inheritance. They've been making those things for a hundred years. You'd think that any product that has survived in the marketplace for a hundred years unchanged and yet is still considered the best can't be all bad. The factory is an old victorian house in Los Gatos. I guess their motto is Do what you do well and stick to it.
   / Ta da! 2 dead moles! #5
You must have a different class of moles than I, OP. I've used Victor Out O'sight traps for about five years now. Kill well over 20 moles a year. I'm over 30 this year. I love that I can set them quickly. Just pick the straight run, push down the mound with my foot, cut two slits for the claws, and set the trigger on the run. Yard is too big for grub treatment and I'm surrounded by woods where they thrive. Glad I don't have your moles that need a fancier trap!
   / Ta da! 2 dead moles! #6
Starting last fall, thru a mild winter, into this spring I trapped 37 moles with the Victor old style plunger traps. Am Mole free so far this summer. Just gotta know how to set 'em.............and take the time to do it. Surely "Man" is smarter than "Moles".:laughing:
   / Ta da! 2 dead moles! #7
I've also had a lot of mole problems over the years. I've never messed with the traps but have tried the poison. We have lived there for 20 years and I've killed maybe 5. I've killed them by digging them up when I see the ground move. They are actually kind of cute until you look at their face. I toss them up in the air and take batting practice. I have spread stuff to kill the grubs but that is very temporary. Like mentioned by a couple of people you have to be pretty vigilant to keep them away from your yard.
   / Ta da! 2 dead moles! #8
I don't mess with them. Kitty Cat, on the other hand, leaves us one per week on the front porch. Hmmm, maybe I have to say I mess with them after she kills them. I shovel em off the porch and throw em into the woods.
   / Ta da! 2 dead moles! #9
You can do what I do - get a couple of dogs. Mine catch moles all the time (actually nothing lives on my property). The drawback to my method is that when the dogs dig up the moles, they do 10x the damage as the moles could ever do! :D
   / Ta da! 2 dead moles! #10
You sure your Kitty cat is catching moles or are you talking shrews? A mole is about the size of a guinea pig and they live pretty deep (and are not pretty animals other than that coat). Somebody above posted about grubs...if that is the problem then you might want to look into that (and if you have a skunk problem you will get two birds with one stone). A heavy dose of lime on the lawn cut down on the grubs...unfortunately common lawn weeds LOVE lime also so it now becomes a coin flip...do you want to do lime and deal with the "weed and feed" or not...
Schuler 125BF Feed Wagon (A59814)
Schuler 125BF Feed...
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
FUEL CELL (A58214)
FUEL CELL (A58214)
Bell 1600 Gallon Nurse Trailer (A56436)
Bell 1600 Gallon...
