T4030 starting issue. Injection pump?
/ T4030 starting issue. Injection pump? #1
Patf10
Holbrook, Pa
Ford 3000, Ford 4630 4wd, New Holland 1720, Kubota B7100HST
I have a t4030 that I’m having some cold starting issues. When it’s cold maybe 15-20 and lower it will start. However after running for maybe 30-60 seconds it slowly dies. To get it to start again I have to bleed the injectors. I have cleaned out the fuel tank, new lift pump, new filter, new lines replacing the plastic quick connect lines. If it’s warmer out. Maybe 20 and above it will start and run just fine. Fuel isn’t gelled. I have to put a torpedo heater on the engine. To get it to start and stay running on the colder days. Any ideas what the issue could be?
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Tire Balancer (A61570)
2007 Reefer Trailer 53ft (A61165)
2007 Reefer...
2014 Lincoln MKC SUV (A61569)
2014 Lincoln MKC...
Kubota M7040 Tractor (A61166)
Kubota M7040...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
